Page 8 of 18
Re: Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Posted: 15 Apr 2025, 20:19
by daviddave1
Very interesting topic.
Just ordered a huaham HDMI 2.1. Fiber Optic from https://www.amazon.nl/dp/B0CYX1858V?ref ... title&th=1 for my 540hz Zowie Xl2586X
Also put my RAM on 1T 7400 instead of 2T 8000 for my DDR5 13900KS build . ( Doing some stabilizing testst atm) there are rumors though that my Gigabte Z790 AORUS TACHYON X
Mobo has a fake 1T setting? so its not real 1T? it wont boot on 1T 8000 so it has to be real right?
Posted: 15 Apr 2025, 21:13
by akylen
daviddave1 wrote:
15 Apr 2025, 20:19
If you have the problem , could you write here when it arrives if the cable did fixes something for you please ?
Posted: 15 Apr 2025, 22:07
by JimCarry
daviddave1 wrote:
15 Apr 2025, 20:19
does your pc boot on 8000 or not on any t ,and are you a cs2 pro ?
Posted: 16 Apr 2025, 04:50
by daviddave1
JimCarry wrote:
15 Apr 2025, 22:07
daviddave1 wrote:
15 Apr 2025, 20:19
Yes my pc boots on 2t 8000 and its stable. It does not boot on 1t 8000.
Posted: 16 Apr 2025, 04:51
by daviddave1
akylen wrote:
15 Apr 2025, 21:13
daviddave1 wrote:
15 Apr 2025, 20:19
I am not sure if I have the problem. But I will let you guys know if I feel a difference with the new cable.
Posted: 16 Apr 2025, 06:21
by daviddave1
also it seems the Tachyon X Z790 does not support real 1t/1n Maybe gonna switch to the ASRock Z790I Lightning WiFi. Have to get some confirmations ASRock Z790I Lightning WiFi rreally supports it though... edit seems like u need apex, dark, unify or iedge for the Z790 platform.. checking now what board has the asmedia usb port and the non usb sound card...
seems like the DARK KINPIN is the only board that has that.
My eye has fallen now on the MEG Z690 UNIFY-X seems like it supports real 1N. Have to buy a MCU-based soundcard to get low audio latency to circumvent the ALC4080 card on it that is routed trough USB.
Posted: 16 Apr 2025, 10:02
by daviddave1
kyube wrote:
03 Apr 2025, 18:44
amorou wrote:
03 Apr 2025, 16:45
Video (most bandwidth heavy) signals use fiber , rest is not important they re audio vs
And where did you get idea of he got unstable ram settings
The rest is in fact important... lol
If his assumption was that the DisplayPort cable was a EMI source, then he doesn't eliminate it fully with these hybrid-optical fiber cables. He only dampens the effect, but there's still copper in those cables.
If his assumption was that the DisplayPort cable allows for conducted interference to enter his display, then it's not eliminated with these hybrid-optical fiber cables.
Anything past 3200–3600MHz 1T on Skylake gen Intel CPUs is unstable.
Anything past 6000-6600MHz 1T on Alder-Lake gen Intel CPUs is unstable.
These are numerical values which have been obtained from running various stress tests for extended periods.
To skip testing all of this testing, opt for QVL of mobo vendor (and hope they've done a good job testing the kits) or run EXPO/XMP disabled. Very simple setup.
do you have a recommendation for a 13900ks mobo that run TRUE 1T? Apparently my Z790 AORUS TACHYON X runs fake 1T and its hard to check the status of CMD_Stretch ( CMD Stretch messed with 1T so it becomes fake) on a intel cpu. Google and Chatgpt leaves me in the dark on how to check the actual status of CMD Stretch using rweverything. Do you maybe know how to check? If i dont get a confirmation my Z790 AORUS TACHYON X with A-die RAM runs true 1T or not I am gonna sell it for a MSI MEG Z690 UNIFY-X.
Posted: 16 Apr 2025, 12:26
by Randomguy007
daviddave1 wrote:
15 Apr 2025, 20:19
I ordered the exact same cable, for me perfect gameplay now. I hope for you too
Posted: 16 Apr 2025, 15:23
by JimCarry
Randomguy007 wrote:
16 Apr 2025, 12:26
daviddave1 wrote:
15 Apr 2025, 20:19
ok so you and op confirmed that this cable is working,very nice can someone give link for europe besides amazon link ?
Posted: 16 Apr 2025, 15:51
by iwabik
All of yours reports made me want to try this. I ordered the exact one from Amazon OP linked. I'm not having much hope as I believe the problem lies more in the game itself (CS2), but worst case scenario I'll just return it I guess, so why not give it a shot.
I will report when I get it, but it'll sadly be after Easter.
