HUGE Fix at Input Lag!!!!
Shakilnobes
Re: HUGE Fix at Input Lag!!!!
Post by Shakilnobes » 20 Apr 2021, 04:28
Are you using GPU or DISPLAY SCALING on your 360hz?
Sandy
Post by Sandy » 30 Jun 2024, 15:49
pox02 wrote: ↑
15 Nov 2020, 20:42
if u want really low input lag for overwatch try my settings :)
why set refresh rate to ff0? its hidden feature that nvidia missing its called low-Latency REFRESH_RATE_OVERRIDE_LOW_LATENCY_RR_MASK
u can check here https://docs.nvidia.com/gameworks/conte ... gs_8h.html
DISALLOWED is the lowest input lag flip is good to but if u want hit ur shots over smoothing try it
now the real settings that give u snappy mouse movement
MAX_PENDING_CMD_BUFFERS to 0x1 remove the stutters/lag
MCFORCEHOSTSTAGINGBUFFERSIZE this is really fun u can check it over 1000 but recommending not go above 20 set it 0x00000001 for extreme mouse input lagless
enjoy the fastest mouse input in ow :)
one more thing i forgot to say to u make sure low latency is off cause disallowed work best with off
I don't know why my nvidiaProfileInspector does not have MCFORCEHOSTSTAGINGBUFFERSIZE
Post by Slender » 05 Jul 2024, 23:32
Sandy wrote: ↑
30 Jun 2024, 15:49
pox02 wrote: ↑
15 Nov 2020, 20:42
because all of that outdated
