Reduce Input Delay (Mouse & Keyboard Buffer Size)
masneb
Re: Reduce Input Delay (Mouse & Keyboard Buffer Size)
Post by masneb » 14 Jul 2023, 02:15
0 was a metaphor, approaching zero, but not being zero.
Sure default value is 100, registry key isn't normally there, 0 being not applicable. Almost everyone talks about the value in terms of decimal, because using hex means almost nothing to anyone talking about this specific subject.
You can use 4 instead for instance if you want to witness the same behavior, most people start having erratic mouse issues around lower teens.
I could definitely do a blind test and figure out if it's different, but not the specific value if that's what you're gunning for. Still trying to figure out what value is best.
0ka
Post by 0ka » 14 Jul 2023, 12:08
masneb wrote:
14 Jul 2023, 02:15
discord? 0ka#5689
Sandy
Post by Sandy » 08 Jul 2024, 13:05
Rallaz wrote:
14 Sep 2021, 01:54
Eonds wrote:
13 Sep 2021, 17:13
Rallaz wrote:
13 Sep 2021, 13:00
Eonds wrote:
13 Sep 2021, 08:11
Maybe you typed something wrong, or you're just not capable of seeing it. It's pretty obvious for most people though. It's a legit tweak that's documented by microsoft.
I don't say you could be wrong just saying I don't think it does anything on my end since I've a Steelseries APEX TKL and acution point at 0.4 which extremely fast, in Rocket League I've been around top 100 for a long time each and every season.
My PC is some what very high-end as well.
240hz monitor
3080 FE Nvidia
G.Skill 4266mhz (15-15-15-28)
Asus Maximus XI CODE (modded)
Corsair 1000AXi
Every Cable is shielded as well.
Is there some important step I'm missing in the video, I'm trying this as well right now, this moment. Can't really feel the difference. I play Rocket League with KBM as well.
My problem is most likely the power as in many other threads.
Your problem is probably your 240hz monitor + gpu, still your setup is very premium. Your RAM could be unstable & what about your CPU ? I also play rocket league at a high level, try setting them both to 0, and can you send me a picture of yours so i can see if you misspelled something.
I will do when I get home I will try running at "0" and send you a screenshot of my settings in RegEdit
CPU is i9 9900K running at 5.0ghz. all the time. No Hyperthreads (HT)
GPU at 1980mhz with 60C
About my RAM I just tested it 2 days ago and it passed memtest86. ( I will test them again when I get home but I doubt it gonna change any result).
As I said I still don't think there is a difference on my end. I also tried 240hz in rl and 120hz there is no difference.
I still think it is power related 100% since its almost perfect already.
If you got some other tip on how I prevent the small few percentages from changing during specific hours please let me know,
@Eonds feels like I'm only chasing this last few %'s
Every time I change this value it works but after a while the input lag comes back. It seems like the input lag is an internal delay of Windows and can never be removed?
