Page 79 of 112
Posted: 10 Sep 2021, 17:17
by Mugabi
blackmagic wrote:
10 Sep 2021, 17:08
Mugabi wrote:
10 Sep 2021, 16:31
hiro wrote:
10 Sep 2021, 15:41
Got reply from my power company and my Problem is Harmonic Distortion as expected, which they will fix with active harmonic filters because its over the limit or something and it can damage devices when not fixed. Got a new fusebox, grounding and connections to the house aswell. I will report back if it changes anything, they said it takes like 2-3 weeks....
Wtf is harmonic distortion and whats the main source of it?
something like this...
https://youtube.com/watch?v=yC9HXxsOTY8
Ahaha nice video choice. They should send you documents explaining the sources of this,the magnitude of these harmonics and how much damage they can do. Tell them to do that if possible
Posted: 10 Sep 2021, 23:08
by nyxo100
hiro wrote:
10 Sep 2021, 15:41
you are my new guardian angel
Posted: 13 Sep 2021, 12:42
by InputLagger
mendiguera_ wrote:
08 Sep 2021, 21:35
Hi, I've been following this topic for a while and I've always felt a lot of inconsistency in my mouse. A few days ago I've been doing tests using MouseTester v1.5 and noticed a very strange graphic.
Mouses: razer viper mini and zowie fk1+ both with 1000hz
Can anyone explain to me?
Can someone with inconsistency issues test it too?
I have this issue too. LOOK AT THIS SHIT !
Posted: 13 Sep 2021, 16:06
by nick4567
InputLagger wrote:
13 Sep 2021, 12:42
mendiguera_ wrote:
08 Sep 2021, 21:35
do you at the very least have a comparison for what normal should look like mate it does us no good to just see this without seeing a comparison to what a normal would look like lol
Posted: 13 Sep 2021, 17:21
by Eonds
Those graphs are meaningless. It's probably your OS being bloated mate. The mouse works fine for me, I have the RGB off, optimized OS,BIOS, and anything else you can think of.
Posted: 14 Sep 2021, 03:43
by Slender
Here you are sitting for 80 pages saying that you have an EMI, have weak non-configured computers, buy all sorts of junk for your dirty network, and what's the use? show at least 1 inputlag test where a person compares a clean and dirty network, where? You're just crazy.
Posted: 21 Sep 2021, 10:45
InputLagger wrote:
13 Sep 2021, 12:42
I've also seen that before on a non-electricity-related non-interference-related issue. I'm not sure this is inteference/EMI unless you've seen this disappear with tweaking such as Spread Spectrum or relocation away from electrical fields.
Posted: 21 Sep 2021, 11:28
by Eonds
InputLagger wrote:
13 Sep 2021, 12:42
mendiguera_ wrote:
08 Sep 2021, 21:35
That's what happens when you don't optimize your PC. Your CPU gets starved and interrupted causing your mouse to feel like shit + game stuttering.
Posted: 21 Sep 2021, 14:55
by Xehet
Eonds wrote:
21 Sep 2021, 11:28
From what I understand you are knowledgeable on how to optimise Windows. Is there any guides you can recommend to follow to optimise Windows thoroughly?
Posted: 21 Sep 2021, 19:07
by Eonds
Xehet wrote:
21 Sep 2021, 14:55
Eonds wrote:
21 Sep 2021, 11:28
No not really. There's really basic bot ones from people like FR33THY (doesn't know much) but it's better than nothing. I'd be down to help you go over the critical stuff (DM me on twitter, I have my twitter on my blurbusters profile) I just think it's important more people realize that before you claim your issue is an external force, you might want to have all the internal things properly tuned. 99.99% of people don't. I've actually gone to the lengths of testing, buying good gear, using a ultra high FPS camera, checking so many things. At the end of the day i live next to 5G/4G towers, I live in a condensed area with a shit ton of transformers, satellites, routers, radios, smart TV's, smart LED's, AC units etc. I own two PC's an intel based system & a Ryzen system. The only common denominator is the GPU (GTX 1070/1070 ti). I'm now in the process of getting a 1GB line installed (200$ USD a month btw LOL) just incase i'm tricking myself somehow (i have really slow ADSL normally). The main thing is, the input latency/stuttering/desync happens offline. I've tested so many variables and honestly it's just tiring. I can still play really well with 1GB sub 20ms, a CRT, 8khz mouse & keyboard, sub 130ms reaction time, ryzen pc, shit GPU, etc. I'll also add the intel system is 100% better than the ryzen one probably due to clock speeds & architectural latency differences. My house also has really old wiring and everything where I live is just scummy. It's probably my houses sh1t wiring/grounding. I don't give a fuck anymore, i still body kids in game @ a pro level. At some point you do what you can with what you have. I'm all for improving latency & diagnosing/fixing issues that make no sense at the surface level. I'm just saying I have REAL issues that are reproducible & clearly not a mental issues. I can literally turn my box fan speed and it can be heard through my headphones. I'll even pick up interference on my mic and headphones. Even my keyboards RGB is loud as fuck and causing a loud noise in my mic. It's really frustrating knowing these people probably don't have the same issue as me and claim they do.
