Odyssey G7 part 2 vs Nano IPS review (TRIPLE REVIEW). IN PRACTICE and Viewsonic elite xg270qg ULMB vs Samsung odyssey g7's MBR. who wins? but before i talk about that, watch this video first on how I found all of these motion artifacts
As you can see,i too have my own personal "blur busting" tool. So i'm going to give credit to mark from blurbusters since i am clearly copying his UFO test but i'm copying it in PRACTICE based off the game i play the most. so plz don't sue me LOL
I'm sort of saddened how so many ppl truly believe the "black smear" from the odyssey G7 doesn't exist. Despite it CLEARLY showing on the UFO tests from mine AND hardware unboxed. Hate to say it but those
UFO tests never lie. I truly believe that those UFO ghosting tests are the most accurate way to measure response times relative to other monitors. I will PROVE everything in this post [/b] Here is hardware unboxed UFO ghosting test 240hz adaptive sync
post a picture (TOP alien)
here is my samsung odyssey g7 UFo ghosting test at 240hz adaptive sync ON
(middle alien 960 pixel speed, cyan)
viewsonic elite xg270qg ULMB @120hz SMH....
Scroll all the way down to see the results. Otherwise, i will post the review of the nano viewsonic and nano LG monitors first
LG 27gl850-b and viewsonic elite xg270qg double review
Overall.
LG 27GL850-B and
viewsonic elite xg270qg are ultimately the best monitor i have ever tested in my entire life. Literally almost every thing ticks with these two monitors
Imagine owning a monitor that is
1 in colors (no other monitor is more vibrant since 98% dci-p3 and 133% SRGB is the highest color gamut you can get for gaming.
1 in response time( relative to other 1440p IPS monitors. Based off my tests, there isn't any other monitor that comes close in response times as these two, only TN is capable of being faster)
These two monitors fit that mold and they exemplify what a monitor should be when it comes to QUALITY. In my opinion, they are 100% worth your money
These two monitors are the ULTIMATE gaming monitor you can buy today The LG27GL850-B is the ultimate winner and the best overall monitor that I have personally ever tested followed by the viewsonic elite xg270qg.
(flashlighting was fixed since i used a semi-damp cloth to massage it out, also the camera detects IPS glow much more than my own two eyes, i was not able to see ANY glow, it looked dark)
slight flashlighting(BLB) on bottom left corner but it's very feint and almost every viewsonic monitor has it anyway. Otherwise, i got ucky with this panel since there is no bad backlight bleed.
UFO pursuit ghosting test(zero artifacts, NONE nada zilch). This has probably the most feint inverse ghosting i've ever seen where the inverse ghosting coronas are invisible. I didn't see ONE inverse ghosting corona when i did my cannonball test on rocket league and that game is Excellent at showing them. 0.5% overshoot error rate. Also, these two monitors have the best PIXEL inversion/pixel walk results that i've seen when using LAGOM. (btw, all 30ish monitors i've purhcased failed that lagom pixel walk test, but these two ultimately faile the least in that test.
LG 27Gl850-B 144hz OD Fast
Viewsonic ELITE XG270QG 165hz OD standard
Viewsonic ELITE XG270QG backlight strobing @120hz
MBR from odyssey g7 and
ULMB from viewsonic xg270qg IN PRACTICE RESULTS(WARNING! these unwanted motion artifacts/motion blur/etc
may annoy you!).
Both the viewsonic elite xg270qg and the samsung odyssey g7 ellicit
quadruple cross talk . only difference is, the odyssey g7 doesn't have that annoying red phosphor that may give ppl seizures thanks to the wide color gamut backlight.(thisi s probably the reason why the lg 27gl850-b chose to not make it a native g-sync monitor.
viewsonic elite xg270qg red phosphor(red monster, red death). I rank this as the
#1 most ANNOYING artifact ABOVE black level smearing.
2nd most annoying unwanted artifact is BLACK LEVEL Smearing(This is samsung odyssey g7's black level smearing IN PRACTICE)
more black smearing from the odyssey g7
MBR from the odyssey won't save you. Instead you will see QUADRUPLE crosstalk
MBR OFF? you see this black smear artifact(this isn't the fresnel effect, that's a legit unwanted black smear)
inverse ghosting corona and blacksmear at the same time? Yup, the odyssey g7 can make this possible.
Tried another FPS title that i rented on steam and nothing changed
Black smear makes EVERYTHING BLURRY based off my tests especially when you move your camera.
Blacks are SO dominant and the most common color that if a darker shade of grey smears, EVERYTHING WILL LOOK EXTREMELY BLURRY.
The odyssey g7's black smear artifacts are a GODSEND compared to this monstrosity(viewsonic elite xg270qg ULMB). It's
not just moving objects, but EVERYTHING!! it's so bad that i had the viewsonic nano IPS as DEAD last above the xg279q and the odyssey g7's Strobing.
I have the crosstalk aggression graph but i will post that in a few days since i will do an ultimate update
Fun fact! the viewsonic elite xg270 is RANKED #1 overall whereas the viewsonic elite xg270qg ranked DEAD LAST overall. Samsung odyssey g7's MBR ranked 2 notches above
IN CONCLUSION
the viewsonic nano IPS is still better than the odyssey g7 because even without its ULMB, it's still a GREAT monitor overall. Fast response times, excellent colors, good quality. The odyssey g7 on the other hand doesn't have anything going for it.
1. HDR600 in my opinion is useless, adds too much input lag, and should be turned off at all times
2. the curve may not be a preference for some people. My cousin said "it looks like a monitor with a deep bend in the middle and not in a good way"
3. Adaptive sync ON 240hz has black level smearing. It doesn't matter if the response times are fast It can have a 0.1ms g2g for all i care. If there is BLACK smear, it will SHOW and the BLUR annoyed the hell out of me! Unfortunately, that is synonymous with this technology they call VA.
4. the contrast ratios(although id ont' have hardware to measure it, from what i've seen is 2000:1. The MSI MAG251RX has a contrast ratio of about 1200:1. (800 less,) which is noticeable but not to the point where you have to compromise black level smearing, a $700 price tag, bad viewing angles
5. Lastly and
most important of all. 240hz at 1440p resolution. NO modern AAA title can RUn 240hz framerate at 1440p resolution, not even the fastest GPU rtx 2080ti. The fastest that i've seen was about 140hz-155hz(far cry 5), and that is with LOW settings, basically it would need another 90hz make it to 240hz FPS. So it's not even remotely practical. it's counter productive and redundant.And because this isn't a native g-sync monitor, without variable overdrive, this montior isn't safe from microsttuters, stutter, judder, more ghosting, more input lag if the framerate deviates too much from the refresh rate.
6. Input lag. More input lag than the other IPS monitors i've measured. Also, for some weird reason, adaptive sync off has more input lag than adaptive sync on. And
whenever you change the OVERDRIVE setting, the input lag is NOTICEABLY worse or better depending on what refresh rate. If anyone have any answer to this, feel free to respond or PM me. I'm guessing it's the technology(VA) that is causing this but i'm not too sure.
I gave this monitor(odyssey g7) a
1/10 and i ranked it DEAD LAST among all of the monitors i've ever owned.
I'm sorry but THE MORE EXPENSIVE THE MONITOR IS, THE MORE STRICT MY EXPECTATIONS. $700 IS insane relative to the specs that are basically redundant/impractical if you think about it logically.
point of reference.
PS,it may look like i'm bashing the odyssey g7. But lets be real here. The PRICE TAG is $700. Think about it... I tell myself this.
if somethiing is $700, "IT BETTER BE GOOD" " IT BETTER HAVE THIS, IT BETTER HAVE THAT" and yes, i'm going to admit, my expectations are VERY high if i buy something as expensive as the odyssey g7. So yes, i will admit that i am bashing this monitor but
justifiably so relative to its ridiculous pricetag. Hopefully, i get some empathetic readers here who know where i am coming from as a consumer.
also, acer predator x25 360hz monitor. $1100 USD, oh boy. I CANNOT WAIT!! I will be SUPER strict with this because the
price tag is BEYOND ridiculous. The odyssey g7 did NOT live up to the hype. I rest my case. My suggestion is, wait for this monitor to drop to $400-$450. It's STILL a fun monitor to use.
-RLCS
the VG259Qm, VG279qm MSI MAG251RX and the fixed 60hz input lag PLAGUE IS NEXT! Sorry for the delay but the vg259qm will be reviewed next. I just wanted to BUST the odyssey g7's BLUR first.
