Page 9 of 10
Re: Questions about new G-Sync monitor
Posted: 02 Jul 2017, 13:02
by parini
It is very visible at 0:16
Posted: 02 Jul 2017, 13:09
by jorimt
Thanks for the video parini.
I see a couple of brightness fluctuation across the whole screen at the 0:16 mark, is that what you're talking about? I'm assuming this doesn't happen with G-SYNC off?
If so, I'm not sure what that is.
Posted: 02 Jul 2017, 13:12
by parini
With gsync turned off, this does not happen.
Posted: 02 Jul 2017, 13:13
by jorimt
What is your framerate when this happens?
Posted: 02 Jul 2017, 13:15
by jorimt
Also, do you have "Dark Boost" or "Adaptive Contrast" enabled in the monitor menus? If you do, try disabling those.
Posted: 02 Jul 2017, 13:18
by parini
100fps Where are these options?
Posted: 02 Jul 2017, 13:26
by jorimt
In your monitor menu, here's an image from the manual (ignore the brightness and contrast numbers):
Posted: 02 Jul 2017, 13:27
by parini
I found here both are disabled.
Posted: 02 Jul 2017, 13:31
by jorimt
If you disabled both of those, and you were at 100 FPS when that happened in the video, I don't know what it is.
G-SYNC can flicker at low framerates (30 FPS or under) on some TN panels, but the brightness doesn't fluctuate like your video.
It could be your monitor. I would not go so far as to say it is faulty or broken though.
Have you contacted Acer and shown them the issue?
Posted: 02 Jul 2017, 13:35
by parini
I have not warned them yet.
