BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
krollic
nvm
senny22
Ok cheers, How would I know that 180 is truly is stable though? I played 2 counter-strike games with it enables yesterday and it seemed to work fine (altghough a bit blurry since i'm used to 128hz with blur reduction).hleV wrote:For what it's worth, I'm at XL2411Z V4 and while it's able to do 210Hz, eventually the screen will become white due to an unstable overclock. Same even at 185Hz. At 180Hz it's perfect.senny22 wrote:Hi! I'm really happy that this works but somewhat let down by the fact that I can't get over 180hz. Would a firmware update for my monitor potentially help? I have one of the oldest revisions of the XL2411Z.
As for the OOS Fixer, do I simply download the exe and put it in %ProgramData%\Microsoft\Windows\Start Menu\Programs\StartUp?
senny22
Hi! So I've discovered that if I want to go above 180hz, I must use the "LCD Reduced" option when creating custom resolutions in CRU (although "LCD Native works as well but then flicker occurs. "LCD Standard" only works up to 180hz. I managed to get all the way to 240hz (didn't try any higher) using LCD Native. However, the image was very unstable with flickering and artifacts. I just thought that might be worth mentioning in the OP. LCD Reduced got up to 200hz stable without ant artifacts.
- hleV
Get OOR Buster .exe from here:senny22 wrote:As for the OOS Fixer, do I simply download the exe and put it in %ProgramData%\Microsoft\Windows\Start Menu\Programs\StartUp?
https://github.com/hleVqq/OorBuster/releases
(Add it to startup folder if you want it to auto-start if you're using overclocked Hz at all times and not only enabling it for certain games.)
BenQ XL2546K @ 240Hz (DyAC+) • ROCCAT Kone Pro Air @ 1000Hz • HyperX Alloy Origins • CORSAIR MM350 PRO Premium • HyperX Cloud Revolver • NVIDIA GeForce RTX 3070 @ 2130MHz/8000MHz • Intel Core i7-8700K @ 4.8GHz • G.SKILL RipjawsV 16GB (2x8GB) 3000MHz CL15
senny22
I placed the "OorBuster" Application in the "startup" folder in "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp" and while it does start up automatically with windows, the monitor stays "out of range" unless I do it manually through "softMCCS". Any idea? Is it only the application that should be in the startup folder?hleV wrote:Get OOR Buster .exe from here:senny22 wrote:As for the OOS Fixer, do I simply download the exe and put it in %ProgramData%\Microsoft\Windows\Start Menu\Programs\StartUp?
- hleV
Out of Range should fix automatically as soon as Windows starts the program. Sometimes it takes a while for it to start after PC boot, so you're stuck with Out of Range screen during that time. Or it fails to start OorBuster.exe for some reason.
* There might be other issues, such as OorBuster.exe failing to retrieve the monitor's handle, etc. but they don't happen that often.
senny22
Okay, I don't know what the isue is but the program is running in my windows tray as well as task manager. It doesn't fix the Out of range error though no matter how long I wait after starting up my PC.hleV wrote:Out of Range should fix automatically as soon as Windows starts the program. Sometimes it takes a while for it to start after PC boot, so you're stuck with Out of Range screen during that time. Or it fails to start OorBuster.exe for some reason.
- hleV
Which Windows version are you using? Maybe the screen wake up event isn't fired for some reason when the app is launched on your PC, you could try getting the older version "OOR Fixer" and see if that helps with OOR fix on boot, as it doesn't wait for the event but does the fix forcefully upon launch. (OOR Fixer doesn't have the fix-on-screen-wake-up feature, but if you confirmed that it works for you, I could update OOR Buster.)
senny22
hleV wrote:Which Windows version are you using? Maybe the screen wake up event isn't fired for some reason when the app is launched on your PC, you could try getting the older version "OOR Fixer" and see if that helps with OOR fix on boot, as it doesn't wait for the event but does the fix forcefully upon launch. (OOR Fixer doesn't have the fix-on-screen-wake-up feature, but if you confirmed that it works for you, I could update OOR Buster.)
Cheers, that version worked for me (although I have to sign in to windows first with a "out of range" black screen but I know what to press so it doesn't matter much). I'm using Windows 10 version 1903 btw. Is any of the "OorFixer" version supposed to work when entering a game that changes the resolution? for example when launching csgo at 180hz but having the desktop at 120hz?
- hleV
Yes, both OOR Fixer and OOR Buster should work in your described scenario.senny22 wrote:Is any of the "OorFixer" version supposed to work when entering a game that changes the resolution? for example when launching csgo at 180hz but having the desktop at 120hz?
