Strongz wrote: β28 Jul 2020, 20:59I am Spanish-speaking and sometimes I don't understand very well when google translates for me. I have the same symptoms that almost everyone with this problem with the difference that I take my PC to other houses and it works just as bad, I sold my PC and bought a new one thinking it could be a hardware problem but the problem came back, I changed components 1 by 1 and the symptoms did not go away. Now my theory is that my house does some damage that wherever I take it will have the problem. Now I wanted to ask you what you mean by fixing the problem or you will always live with it. I know it is a problem of electromagnetic interference and now I will install an earth bar to see if this solves my problem or what you recommend doing.Nawafwabs wrote: β24 Mar 2020, 13:36I did this test 2 days and i check it and it confirmed that the emi is the main issue
if you think power condition will fix it 100% this is wrong
You need to fix the hole house or you face this delay all your life or maybe you move to other house and do emi test over 24 hours to make sure not effect by other things
https://youtu.be/wGfhfayYfHU
Installing earth with 0 ohm will help
https://youtu.be/G2OtgeDkTLs
And reduce high emi will help you also
https://youtu.be/QbWLJ2-s8a4
