The full path to fix the problem.
naporitan
Re: The full path to fix the problem.
Post by naporitan » 05 Oct 2025, 06:14
Set up a new system based on the Ryzen 7 7800x3D processor.
Everything works well.
Windows 11 home 25h2 (Always reset clear cmos before installing a new system.)
mobo: b650 aorus elite ax v2
ram: F5-6000j3636f16gx2-tz5rs
bios settings:
expo mode - enabled
csm support - disabled
secure boot - enabled/custom mode
keyboard: IPI AURORA65 (Silver, Lightning Magnetic Switch)
keyboard settings: all settings are default
monitor: xl2546 (picture mode - gamer 1, dyac disabled)
viewtopic.php?p=118877#p118877
naporitan
Post by naporitan » 06 Oct 2025, 23:14
MontyTheAverage
Post by MontyTheAverage » 07 Oct 2025, 05:17
All these software, hardware, windows, peripherals tweaks.... when are you finally gonna realize the problem is none of these?
naporitan
Post by naporitan » 09 Oct 2025, 06:35
MontyTheAverage wrote: ↑
07 Oct 2025, 05:17
I used to think that the problem was in the electricity or the internet connection, but over time I came to the conclusion that all this was nonsense.
Post by Slender » 09 Oct 2025, 11:33
naporitan wrote: ↑
09 Oct 2025, 06:35
07 Oct 2025, 05:17
Like clockwork, every day, at exactly the same time, the problem appears. And at exactly the same time, every day, the problem returns.
naporitan
Post by naporitan » 09 Oct 2025, 14:41
Slender wrote: ↑
09 Oct 2025, 11:33
naporitan wrote: ↑
09 Oct 2025, 06:35
07 Oct 2025, 05:17
I used to have these problems 24/7.
Post by Slender » 09 Oct 2025, 14:49
naporitan wrote: ↑
09 Oct 2025, 14:41
Slender wrote: ↑
09 Oct 2025, 11:33
naporitan wrote: ↑
09 Oct 2025, 06:35
07 Oct 2025, 05:17
write all specs of your old pc and your new build.
when you move mouse fps is dropping?
naporitan
Post by naporitan » 09 Oct 2025, 14:56
Slender wrote: ↑
09 Oct 2025, 14:49
naporitan wrote: ↑
09 Oct 2025, 14:41
Slender wrote: ↑
09 Oct 2025, 11:33
naporitan wrote: ↑
09 Oct 2025, 06:35
I already wrote my PC specifications in old messages of this topic.
At the moment, I have a Ryzen 7 7800x3d processor and when I move the mouse, the fps drops a little, but this is a normal phenomenon, everyone has this, since I have fps_max set to 0.
naporitan
Post by naporitan » 11 Oct 2025, 16:39
USB Chipset port - Keyboard (Connect the keyboard to a port that is directly connected to the chipset)
USB CPU port - Mouse (Connect the mouse to the USB port that is directly connected to the processor)
H-vdMSnj15n3z-Y1aqdPGvpj6n6NqWUy-wfXDzTdMcA-Y2op2KmlAPzcxzwy9Y5OzlwvfWn7-0md0wiLFc8yDUfg.jpg
H-vdMSnj15n3z-Y1aqdPGvpj6n6NqWUy-wfXDzTdMcA-Y2op2KmlAPzcxzwy9Y5OzlwvfWn7-0md0wiLFc8yDUfg.jpg (1.42 MiB) Viewed 5698 times
cpu - ryzen 7 7800x3d
mobo - B650 AORUS ELITE AX V2
ram - F5-6000j3636f16gx2-tz5rs
gpu - MSI GeForce RTX™ 3090 SUPRIM X 24G
psu - Super Flower Leadex Titanium 850W
cooling - Arctic Cooling Liquid Freezer iii 420mm argb black
ssd - samsung 970 evo plus 500gb
devices
monitor - benq zowie xl2546
mouse - Wlmouse Ying (red)
keyboard - IPI AURORA65 (Silver, Lightning Magnetic Switch)
mousepad - mgg ultraaceaim xsoft
headset - hyperx cloud alpha
naporitan
Post by naporitan » 11 Oct 2025, 21:51
This guy explains very well why you shouldn't change the power plan in game systems.
