What settings for Asus VG259QM 240hz vs 160~fps
geenutz1
Re: What settings for Asus VG259QM 240hz vs 160~fps
Hi, does anyone have an update for the 10-bit colour setting? I have tried using the method outlined in this thread but I don't even see 'Automatic - LCD reduced' at all. Is this due to updates over the years? Any assistance would be much appreciated, thank you all!
HolaSoyDomy
I use 280hz at OD 120, with adaptive sync disabled. When I play Fortnite and my FPS drops a bit, the game gives me mini jerks, is it something in the monitor settings, should I change something? Or could it be a game thing or something else? I have a 5800x3d and a 3070 OC
HolaSoyDomy
My question is, why do you use CTRU and not configure the OD and OC from the OSD of the monitor itself to achieve 280hz and that's it? I don't understand what benefit it has to create a custom resolution, if someone can tell me...
HolaSoyDomy
I don't know if this post is still alive, I have a VG259QM, since I found it at a very good price and in RTINGS I saw that it was a good 1080p fast ips monitor, I have the monitor configured at 280hz and 120 OD, I have seen that some of you use ctru or whatever program to create a custom resolution the same as the standard resolution of the monitor, what benefit does this have or what is it for? Any advice today to better configure this monitor?
