You noticed a difference after changing unavailable settings in the bios? So does it feel the sane or closer to your Intel set up?ffs_ wrote: ↑24 Jul 2020, 01:43I've tested CS:GO on both Intel and AMD and there is a difference, indeed, but rather in mouse movement itself than in input-lag. It was more like comparing mice with different sensors.
On my Ryzen system I had to mod BIOS file to change some settings which are unavailable (not shown) by default. For example, when I have "XHCI Gen1" and "XHCI Gen2" both on "Auto" (which usually means "Enabled") my mouse movement feels like shit, but when I force one of them to disabled -- mouse movement immediately becomes a lot better. Also there are some hidden power-saving options turned on by default (on overclocker's motheboard, wtf?) like "Chipset Power Saving Features", "C1E Support", "PCIe Speed Power Policy", "C6 Mode" and so on.
Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
orangetuner
Re: Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
- A Solid lad
My numbers
- asdaadaa.png (76 KiB) Viewed 10852 times
ffs_
The difference is easily noticeable, at least on my motherboard (Strix X370-F). I wouldn't say it was completely unplayable at stock, but it's surely better now.orangetuner wrote: ↑26 Jul 2020, 08:32You noticed a difference after changing unavailable settings in the bios? So does it feel the sane or closer to your Intel set up?
Brainlet
Keep digging for power saving everywhere and turn it all off. The difference it makes is worth it (better 0.1% lows, less input lag).ffs_ wrote: ↑27 Jul 2020, 03:51The difference is easily noticeable, at least on my motherboard (Strix X370-F). I wouldn't say it was completely unplayable at stock, but it's surely better now.orangetuner wrote: ↑26 Jul 2020, 08:32You noticed a difference after changing unavailable settings in the bios? So does it feel the sane or closer to your Intel set up?
Starting point for beginners: PC Optimization Hub
- axaro1
I can confirm that disabling SMT massively helps on a Zen 2 processor.
My mouse doesn't feel floaty anymore and everything else, even W10, feels way more snappy (I'm on 2004)
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
- MaxTendency
If you're on a 8 core cpu then you may wanna test disabling a ccx and enabling smt (4c8t) and see how that feels input wise as well as fps 1% and 0.1% low on games you play. It may or may not be better than just disabling smt.
- dervu
I made sure that my RAM and CPU are completely stable. Can't remember if previous test was done on higher RAM voltage or not, but I went down with CPU frequency from 4.0 to 3.8 on same voltage and 1.4 on RAM and results look better now with SMT ON than on SMT OFF before.
BEFORE:
https://imgur.com/a/auiKv2B
NOW:
https://imgur.com/a/WrMsgtR
Overall the feel of games is smoother, snappier, more natural. Looks like it is not always so easy to be sure if everything is ok.
BEFORE:
NOW:
canx66
Is it worth to upgrade to a 10900k from 3700x SMT OFF - for input delay purposes? My system on 240hz(v-sync, g-sync on, capped at 237 fps) feels like a brick. Everything is delayed, microstutters.. my brother is on 9900k on 144hz and just by looks its looks very responsive and snappier :-/
LatenyMon ~50us
3600mhz 16-16-16-36
LatenyMon ~50us
3600mhz 16-16-16-36
- BTRY B 529th FA BN
canx66
Oh in the beginning its 50ns.. after a time its higher.
Here is the conclusion of LatencyMon -> https://imgur.com/6YPp269
I tweaked everything, what was necessary
The Mouse and Keyboard I dont have to test, because I had both, before I upgraded.
