Page 10 of 22
Re: Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
Posted: 26 Jul 2020, 08:32
by orangetuner
ffs_ wrote: ↑
24 Jul 2020, 01:43
I've tested CS:GO on both Intel and AMD and there is a difference, indeed, but rather in mouse movement itself than in input-lag. It was more like comparing mice with different sensors.
On my Ryzen system I had to mod BIOS file to change some settings which are unavailable (not shown) by default. For example, when I have "XHCI Gen1" and "XHCI Gen2" both on "Auto" (which usually means "Enabled") my mouse movement feels like shit, but when I force one of them to disabled -- mouse movement immediately becomes a lot better. Also there are some hidden power-saving options turned on by default (on overclocker's motheboard, wtf?) like "Chipset Power Saving Features", "C1E Support", "PCIe Speed Power Policy", "C6 Mode" and so on.
You noticed a difference after changing unavailable settings in the bios? So does it feel the sane or closer to your Intel set up?
Posted: 26 Jul 2020, 17:06
by A Solid lad
My numbers
Posted: 27 Jul 2020, 03:51
by ffs_
orangetuner wrote: ↑
26 Jul 2020, 08:32
The difference is easily noticeable, at least on my motherboard (Strix X370-F). I wouldn't say it was completely unplayable at stock, but it's surely better now.
Posted: 27 Jul 2020, 05:29
by Brainlet
ffs_ wrote: ↑
27 Jul 2020, 03:51
26 Jul 2020, 08:32
Keep digging for power saving everywhere and turn it all off. The difference it makes is worth it (better 0.1% lows, less input lag).
Posted: 03 Aug 2020, 09:03
by axaro1
I can confirm that disabling SMT massively helps on a Zen 2 processor.
My mouse doesn't feel floaty anymore and everything else, even W10, feels way more snappy (I'm on 2004)
Posted: 03 Aug 2020, 15:50
by MaxTendency
axaro1 wrote: ↑
03 Aug 2020, 09:03
If you're on a 8 core cpu then you may wanna test disabling a ccx and enabling smt (4c8t) and see how that feels input wise as well as fps 1% and 0.1% low on games you play. It may or may not be better than just disabling smt.
Posted: 10 Aug 2020, 11:01
by dervu
I made sure that my RAM and CPU are completely stable. Can't remember if previous test was done on higher RAM voltage or not, but I went down with CPU frequency from 4.0 to 3.8 on same voltage and 1.4 on RAM and results look better now with SMT ON than on SMT OFF before.
BEFORE:
https://imgur.com/a/auiKv2B
NOW:
https://imgur.com/a/WrMsgtR
Overall the feel of games is smoother, snappier, more natural. Looks like it is not always so easy to be sure if everything is ok.
Posted: 11 Aug 2020, 05:37
by canx66
Is it worth to upgrade to a 10900k from 3700x SMT OFF - for input delay purposes? My system on 240hz(v-sync, g-sync on, capped at 237 fps) feels like a brick. Everything is delayed, microstutters.. my brother is on 9900k on 144hz and just by looks its looks very responsive and snappier :-/
LatenyMon ~50us
3600mhz 16-16-16-36
Posted: 11 Aug 2020, 13:38
by BTRY B 529th FA BN
Posted: 11 Aug 2020, 16:16
by canx66
Oh in the beginning its 50ns.. after a time its higher.
Here is the conclusion of LatencyMon -> https://imgur.com/6YPp269
I tweaked everything, what was necessary
The Mouse and Keyboard I dont have to test, because I had both, before I upgraded.
