I'M SO CLOSE TO FINISHING MY INPUT LAG!
rol3nd
Re: I'M SO CLOSE TO FINISHING MY INPUT LAG!
Hi, I tried to downlad from the compiled link in the OP (this one: https://www.mediafire.com/folder/ha89h1 ... limWindows)
But for me it says "folder not found", could you update please/can someone else reshare?
empleat
You are lucky I already reposted since I downloaded basically all to my disk! https://drive.google.com/drive/folders/ ... sp=sharingrol3nd wrote: ↑12 Jun 2022, 03:14Hi, I tried to downlad from the compiled link in the OP (this one: https://www.mediafire.com/folder/ha89h1 ... limWindows)
My comprehensive TWEAKGUIDE: https://www.tenforums.com/gaming/117377 ... ost1454596
Anandtech DPC latency tests: https://www.anandtech.com/show/13468/th ... i-review/5
hektor307
Thanks a lot mate
- RamenRider
I don't know why I didn't do this earlier. It's amazing but probably placebo who knows. All I know is in Radeon settings: ste Display settings to have FreeSync enabled but in game settings turn FreeSyncoff.axaro1 wrote: ↑14 Aug 2021, 10:48Today I installed UWP drivers to enable HAGS on my 5700xt setup and it massively improved input lag.
Fps are about the same maybe with a small improvement in 0.1% and 1% but I'm mostly noticing a big difference latency.
I used this guide:
(https://forums.guru3d.com/threads/amd-r ... wp.437511/)
If you guys have input lag issues with Amd GPU I highly recommend to give HAGS a try (either by installing outdated drivers such as 20.5.1 Beta or by installing the latest UWP drivers).
Twitch:https://www.twitch.tv/ramenrider
BB Thread: viewtopic.php?f=10&t=7168
Steam Input lag guide. https://steamcommunity.com/app/1364780/ ... 499/?ctp=3
MisterS0L0
Can you explain how you did it please? I read the OG thread and really couldnt understand a word.RamenRider wrote: ↑29 May 2023, 21:05I don't know why I didn't do this earlier. It's amazing. I'm probably at 99% now.axaro1 wrote: ↑14 Aug 2021, 10:48Today I installed UWP drivers to enable HAGS on my 5700xt setup and it massively improved input lag.
I used this guide:
Mr1991
What is this, just a stripped down version of the driver?RamenRider wrote: ↑29 May 2023, 21:05I don't know why I didn't do this earlier. It's amazing. I'm probably at 99% now.axaro1 wrote: ↑14 Aug 2021, 10:48Today I installed UWP drivers to enable HAGS on my 5700xt setup and it massively improved input lag.
I used this guide:
- RamenRider
You just click the last spoiler where it says How to install...MisterS0L0 wrote: ↑30 May 2023, 13:10Can you explain how you did it please? I read the OG thread and really couldnt understand a word.
You've used DDU before right? Youtube is always good.
Yes
MisterS0L0
I'd obviously read it as id said i didnt understand it. Ive sussed it out now it actually becomes far more clear when you download the zip files.RamenRider wrote: ↑01 Jun 2023, 00:04You just click the last spoiler where it says How to install...MisterS0L0 wrote: ↑30 May 2023, 13:10Can you explain how you did it please? I read the OG thread and really couldnt understand a word.
Yes
The driver isnt just a stripped down driver either its a completely different branch of the driver that excludes the relive streaming element but allows you to use Hardware Accelerated Gpu Scheduling on AMD gpus (my 6800XT anyway) which does make a good difference in input lag actually.
Mr1991
How do you enable hags? Just installed itMisterS0L0 wrote: ↑01 Jun 2023, 06:26I'd obviously read it as id said i didnt understand it. Ive sussed it out now it actually becomes far more clear when you download the zip files.RamenRider wrote: ↑01 Jun 2023, 00:04You just click the last spoiler where it says How to install...MisterS0L0 wrote: ↑30 May 2023, 13:10Can you explain how you did it please? I read the OG thread and really couldnt understand a word.
Yes
MisterS0L0
Had to "Upgrade" to Win 11 and then it was enabledMr1991 wrote: ↑02 Jun 2023, 06:19How do you enable hags? Just installed itMisterS0L0 wrote: ↑01 Jun 2023, 06:26I'd obviously read it as id said i didnt understand it. Ive sussed it out now it actually becomes far more clear when you download the zip files.RamenRider wrote: ↑01 Jun 2023, 00:04You just click the last spoiler where it says How to install...MisterS0L0 wrote: ↑30 May 2023, 13:10Can you explain how you did it please? I read the OG thread and really couldnt understand a word.
Yes
