Page 10 of 12
Re: I'M SO CLOSE TO FINISHING MY INPUT LAG!
Posted: 12 Jun 2022, 03:14
by rol3nd
Hi, I tried to downlad from the compiled link in the OP (this one: https://www.mediafire.com/folder/ha89h1 ... limWindows)
But for me it says "folder not found", could you update please/can someone else reshare?
Posted: 08 Jul 2022, 14:41
by empleat
rol3nd wrote: ↑
12 Jun 2022, 03:14
You are lucky I already reposted since I downloaded basically all to my disk! https://drive.google.com/drive/folders/ ... sp=sharing
Posted: 19 Oct 2022, 15:58
by hektor307
Thanks a lot mate :)
Posted: 29 May 2023, 21:05
by RamenRider
axaro1 wrote: ↑
14 Aug 2021, 10:48
RamenRider wrote: ↑
28 Jun 2020, 21:37
Today I installed UWP drivers to enable HAGS on my 5700xt setup and it massively improved input lag.
Fps are about the same maybe with a small improvement in 0.1% and 1% but I'm mostly noticing a big difference latency.
I used this guide:
(https://forums.guru3d.com/threads/amd-r ... wp.437511/)
If you guys have input lag issues with Amd GPU I highly recommend to give HAGS a try (either by installing outdated drivers such as 20.5.1 Beta or by installing the latest UWP drivers).
I don't know why I didn't do this earlier. It's amazing but probably placebo who knows. All I know is in Radeon settings: ste Display settings to have FreeSync enabled but in game settings turn FreeSyncoff.
Posted: 30 May 2023, 13:10
by MisterS0L0
RamenRider wrote: ↑
29 May 2023, 21:05
axaro1 wrote: ↑
14 Aug 2021, 10:48
RamenRider wrote: ↑
28 Jun 2020, 21:37
I used this guide:
I don't know why I didn't do this earlier. It's amazing. I'm probably at 99% now.
Can you explain how you did it please? I read the OG thread and really couldnt understand a word.
Posted: 31 May 2023, 10:29
by Mr1991
RamenRider wrote: ↑
29 May 2023, 21:05
axaro1 wrote: ↑
14 Aug 2021, 10:48
RamenRider wrote: ↑
28 Jun 2020, 21:37
I used this guide:
What is this, just a stripped down version of the driver?
Posted: 01 Jun 2023, 00:04
by RamenRider
MisterS0L0 wrote: ↑
30 May 2023, 13:10
You just click the last spoiler where it says How to install...
You've used DDU before right? Youtube is always good.
Mr1991 wrote: ↑
31 May 2023, 10:29
Yes
Posted: 01 Jun 2023, 06:26
by MisterS0L0
RamenRider wrote: ↑
01 Jun 2023, 00:04
MisterS0L0 wrote: ↑
30 May 2023, 13:10
Mr1991 wrote: ↑
31 May 2023, 10:29
Yes
I'd obviously read it as id said i didnt understand it. Ive sussed it out now it actually becomes far more clear when you download the zip files.
The driver isnt just a stripped down driver either its a completely different branch of the driver that excludes the relive streaming element but allows you to use Hardware Accelerated Gpu Scheduling on AMD gpus (my 6800XT anyway) which does make a good difference in input lag actually.
Posted: 02 Jun 2023, 06:19
by Mr1991
MisterS0L0 wrote: ↑
01 Jun 2023, 06:26
RamenRider wrote: ↑
01 Jun 2023, 00:04
MisterS0L0 wrote: ↑
30 May 2023, 13:10
Mr1991 wrote: ↑
31 May 2023, 10:29
Yes
How do you enable hags? Just installed it
Posted: 02 Jun 2023, 14:28
by MisterS0L0
Mr1991 wrote: ↑
02 Jun 2023, 06:19
MisterS0L0 wrote: ↑
01 Jun 2023, 06:26
RamenRider wrote: ↑
01 Jun 2023, 00:04
MisterS0L0 wrote: ↑
30 May 2023, 13:10
Mr1991 wrote: ↑
31 May 2023, 10:29
Yes
Had to "Upgrade" to Win 11 and then it was enabled
