Re: Firmware upgrade using Linux tool, requires no hardware
Posted: 28 May 2014, 00:50
So i decided to try this yesterday and cay say that it worked flawlessly, thank you so much pipomolo42 for the information on how to do this, and to Chief for the utility aswell.
I do however have one issue, i cannot for the life of me get the Vertical Total 1350 tweak to work, i get blackscreen whenever i turn on the blur reduction mode.
These are the few different approaches i have taken, all to the same effect.
#TRY 1
1. Enable custom resolution with 120hz and 1350 VT
2. Override the crosstalk and lower persistance in utility
3. Enable Blur reduction on the monitor menu
#TRY 2
1. Enable Blur reduction on the monitor menu
3. Enable custom resolution with 120hz and 1350 VT
#TRY 3
2. Enable custom resolution with 120hz and 1350 VT
(Without enabling override in the utility, leaving values at default)
#TRY 4
2. Enable Blur reduction on the monitor menu
All of the above will leave me with a black screen, it works flawlessly without 1350 VT.
Blackscreen only occurs when i enable the Blur Reduction Mode, the picture returns if i disable it.
If anyone has any input as to how i can resolve the issue it would be much appreciated.
#EDIT
So i noticed some information in another thread about the factory settings in V2 being bad.
Im gonna check on that when i get home, something about Strobe Duty and Strobe Phase having bad values that cause black screen when using VT1350.
I know that Single Strobe is on tho, i noticed that yesterday after checking the firmware version after upgrade.
#TRY 1
#TRY 2
#TRY 3
#TRY 4
#EDIT
