CriticalHit_NL
Post by CriticalHit_NL » 12 May 2026, 15:43
liquidshadowfox wrote: ↑
12 May 2026, 12:46
How do you see if the firmware updates are available for asus or acer a day before? I don't know if the firmware is available unless I put the monitor in firmware update mode and go through the flow on the browser.
Website is indexed through Google so I just happened to coincidentally find it early before it was announced.
That was March 12.
Main System:
i9 13900K @ 0.06v undervolt 0x10B microcode / 128GB (4x32GB) Corsair Dominator Platinum RGB DDR5-5400 CL40 XMP / Asus ROG Maximus Z790 Extreme (early 0219 bios, Sept 2022) / Asus ROG Astral RTX 5090 OC / 2x 990 Pro 4TB / 3x WDC Ultrastar HC590 DC 24TB / 3x HGST He10 Ultrastar 8TB / 1x HGST 7K4000 Deskstar 4TB / Corsair iCUE H170i Elite Capellix LCD 420mm AIO (6x Noctua NF-A14 IndustrialPPC 3000RPM) / Corsair AX1600i PSU (2025) / CoolerMaster HAF 700 EVO / Asus ROG Strix Pulsar XG27AQNGV 1440P 360Hz / Asus ROG Swift PG279Q 1440P 165Hz / BenQ BL2411PT 1200P 60Hz
Secondary System:
i7 3930K @ 4.8Ghz 1.4v / 32GB (8x4GB) Corsair Dominator DDR3-1866 CL9 XMP 1T / Asus Sabertooth X79 (2012 bios 3102) / EVGA GTX1080Ti FTW3 / 1x 840 Pro 256GB / 1x 860 Pro 2TB / 2x HGST 7K4000 Deskstar 4TB / Corsair iCUE H115i RGB Elite 280mm AIO (stock fans in pull) / Corsair AX1200i PSU (2014) / CoolerMaster HAF XM
Third System:
i7 950 @ 3.2Ghz turbo / 24GB (6x4GB) Corsair Dominator/Vengeance DDR3-1600 CL9 XMP / Asus P6T Deluxe V1 X58 / Asus ProArt RTX 4060 8GB / 1x 840 Pro 256GB / 1x WD Blue 1TB / Corsair HX750i PSU / CoolerMaster V6-GT CPU-cooler / CoolerMaster HAF 922
Fourth System:
Core 2 Quad Q9550 @ 2.91Ghz / 8GB (2x4GB) DDR3-1066 @ 1098 Royemai (SK-Hynix) / Gigabyte GA-G41M-Combo (Rev. 2.0) @ 343 FSB / EVGA GTX 560 SuperClocked 1GB / 1x860 EVO 500GB / 1x Samsung HD502HI 500GB / Artic Freezer 7 Pro Rev 2.0 / Corsair HX750i PSU / CoolerMaster Elite 331
rexbinary
Post by rexbinary » 12 May 2026, 19:08
UnDeRTLaKeR wrote: ↑
12 May 2026, 14:58
Does anyone have the issue ?, the display is not detectable by DisplayWidget Center or Armoury Crate.
Armory Crate is permabanned on my PC so I don't know.
EDIT: Also did anyone notice on the new Nvidia drivers released today this note: "Enhanced smoothness when DLSS Frame Generation is used with V-SYNC"
Maybe this helps with Pulsar as well.
EDIT: I seldom post without an edit.
CriticalHit_NL
Post by CriticalHit_NL » 13 May 2026, 08:42
rexbinary wrote: ↑
12 May 2026, 19:08
Well I think this has to do with the issues some people were facing with MFG when for example you were well exceeding 250+ FPS that the GPU utilization suddenly dropped artificially limiting the FPS to a certain value, often triggered by alt-tabbing out of the game but it often did it on its own as well while playing.
So on the PG279Q for example with 165Hz G-sync, whether V-sync was on or forced off or regardless the graphics settings, games like GTA V Enhanced would suddenly drop from 450-500 FPS and lock around ~327 fps when using 4x MFG. There was no way around this but other than disabling G-sync completely because V-sync settings were unable to aid this issue.
The funny thing was that once I lowered the monitors refreshrate to 100Hz the artificial FPS-limitation with 4x MFG started to drop to ~228 FPS instead.
I took a few screenshots back then, below is 165Hz:
100Hz:
Doesn't make sense right?
It is very vague and it was doing it without the Pulsar monitor too with just a secondary 60Hz screen.
Yet the Pulsar monitor did not exhibit these same weird FPS limit issues but it looks like some weird Hz range exceeding/G-sync combination conflicting with MFG with absurd framerates.
You can see how the frametimes went up considerably too, it caused MFG to visibly become unstable and jittery.
This has been happening since the 591.74 drivers.
Other people reported similar issues in games like Black Ops 7.
Now with DOOM TDA I could kind of reproduce it as well by limiting the monitor to 60Hz (PG279Q) and looking at the Sky in the ripatorium and it would start dropping its utilization and framerate too in situations where the Hz limit is far exceeded, no matter the settings used.
Now with the new 596.49 driver that looks solved, partially atleast.
GTA V Enhanced no longer seems to be dropping the framerate as it did before, however, when 4x MFG is active and you alt tab out and back into the game the frametimes start suddenly spiking 0.5-1 seconds or so. Once you disable and re-enable MFG ingame it is fixed until you alt tab again.
For DOOM TDA however 3x MFG seems severely broken now
On every DLSS mode from Performance to Quality and DLAA, it is extremely stuttery/jittery with all settings maxed. However DLSS Ultra Performance seems fine on both old G-sync and new Pulsar monitor.
The 2x FG mode does not seem to exhibit issues on both old G-sync and new Pulsar monitor.
Then 4x MFG is semi-smooth but it also randomly every 0.5-1 seconds the frametimes start jumping up and down from ~10ms to ~25ms so while 4x MFG before felt jittery it now just seems inconsistent, this is only on the new G-sync Pulsar monitor but the frametimes stay flat on the older G-sync PG279Q
Note that I play DOOM TDA with Transformer Model L or E for DLSS 4.5 or Ray Reconstruction, GTA V Enhanced with Preset L.
I've briefly tested the 6x MFG streamline .dll on previous drivers on DOOM TDA before but that actually made the MFG experience horrible with warping graphics in motion so those were definitely not working well on every type of title, but it does for Avatar.
But when other demanding Ray Reconstruction / Path Tracing titles with heavy DLSS modes like Cyberpunk 2077 have zero issues with 6x MFG load I don't think DLAA at 1440P should be any sweat at all for a RTX 5090, so I don't believe this to be some kind of Tensor core related utilization limit but rather software bugs.
Battleye on GTA V Enhanced is plaguing the game anyway when you go Online with 20-minutes long constant frametime stuttering a few minutes into either a full or empty lobby which transfers back over to single-player. Every lobby switch same thing. GTA V Legacy doesn't have it. People are puzzled.
Now the newest drivers I found another problem, atleast under Windows 10 22H2 Pro + ESU, when you try changing the resolution in Windows it no longer blackscreens your display, it just resizes the lower resolution image stretched to the 1440P output signal, the signal doesn't change resolution as observed in the monitors OSD and that counts for all my monitors.
Once you switch resolution in NVCP then the resolution is applied correctly and the displays go black to the new resolution signal.
Main System:
Secondary System:
Third System:
Fourth System:
bahamutfan
Post by bahamutfan » 13 May 2026, 13:18
Hopefully we see the Asus update soon, it’s really been a good while…
Mighty_opf
Post by Mighty_opf » 14 May 2026, 15:30
11 May 2026, 22:25
Nope, just checked and asus still doesn't have the update
:cry: Nothing, let's keep our fingers crossed that we'll have it by next week.
t2na
Post by t2na » 15 May 2026, 03:45
Mighty_opf wrote: ↑
14 May 2026, 15:30
11 May 2026, 22:25
Unusual that the Asus model is so far behind the others, usually Asus are quite hot on being the first with these things or making sure their version is the 'premium' option.
BLooDS_inc
Post by BLooDS_inc » 15 May 2026, 04:23
t2na wrote: ↑
15 May 2026, 03:45
Mighty_opf wrote: ↑
14 May 2026, 15:30
11 May 2026, 22:25
Y, behind, when MSI version even on the new fw don't have pulse width option, lul
Verition
Post by Verition » 18 May 2026, 13:58
The 1.1.6 update for ASUS should be coming today; I asked staff on the NVIDIA forum dedicated to pulsar.
They also announced FW 1.1.7. It won't let me post the link, just created this account to share this.
pgz
Post by pgz » 18 May 2026, 14:25
https://youtu.be/h27x8H6n6p4?t=434
At 7:14 he says the oled is better than the pulsar.
Is this true? 720hertz using 270hz with ULMB 1 is more clear than Pulsar?
mawi
Post by mawi » 18 May 2026, 16:44
pgz wrote: ↑
18 May 2026, 14:25
As far as I understand, he means using the 540 Hz OLED at 270 Hz with ELMB... so black frame insertion which loses a lot of brightness. however this ASUS flaship oled seems to be bright enough so its still fine in ELMB mode.
What confuses me is minute 8:05... Where 120 Hz pulsar easily beats 120 Hz OLED with ELMB. I would have expected 120 Hz OLED with ELMB strobing to be clear as hell, like the 60 Hz mode on pulsar, just with 120 Hz because of the very good oled pixel response times.
But is looks really bad compared to pulsar 120 Hz... very weird.
