Page 97 of 127
Posted: 23 Mar 2022, 10:27
by gbmaster
I am a high level (gbmaster king of wellspring) diabotical player (essentially a quote clone)
I replaced my 240hz ROG with this monitor recently and i'm very impressed, everything feels more real time / precise and smooth.
diabotical is the only game i've tested it on - running at 400+fps consitently.
VRB set to extreme with 390hz is the best combo
Posted: 25 Mar 2022, 15:01
by Softhe
Here are some CSGO settings i think are great
Overdrive Extreme
VRB Extreme
Both of these are fine at normal also
color settings;
r gain; 55
g gain; 50
b gain; 50
r bias; 51
g bias; 49
b bias; 49
r saturate; 100
g saturate; 80
b saturate; 80
y saturate; 55
m saturate; 50
c saturate; 80
Posted: 25 Mar 2022, 15:55
by axaro1
Softhe wrote: ↑
25 Mar 2022, 15:01
Overdrive Extreme
VRB Extreme
color settings;
r gain; 55
g gain; 50
b gain; 50
r bias; 51
g bias; 49
b bias; 49
r saturate; 100
g saturate; 80
b saturate; 80
y saturate; 55
m saturate; 50
c saturate; 80
Color space? I assume DCI due to wide gamut, is it correct?
Posted: 25 Mar 2022, 16:29
by DAG
I currently have de Zowie 2411P 144hz monitor, and I only play competitive CSGO (10 faceit), with no intentions of going beyond that.
My GPU is old (GTX 970), but I have a good CPU and can maintain a 300-700 FPS, depending on what's going on ingame. DM drops to a steady 300-400FPS, for example.
By the way, I have no knowledge about monitors and found out about this one on youtube (Optimum Tech) and got interested.
Considering I only play CSGO and basically do nothing else on my PC, what do you guys recommend? Go for the Acer 390Hz monitor, the Zowie 2546K, or wait for a 360 Zowie?
Posted: 25 Mar 2022, 17:48
by Softhe
axaro1 wrote: ↑
25 Mar 2022, 15:55
Softhe wrote: ↑
25 Mar 2022, 15:01
Overdrive Extreme
VRB Extreme
color settings;
r gain; 55
g gain; 50
b gain; 50
r bias; 51
g bias; 49
b bias; 49
r saturate; 100
g saturate; 80
b saturate; 80
y saturate; 55
m saturate; 50
c saturate; 80
color temp "user", what do you mean by dci?
Posted: 25 Mar 2022, 18:00
Softhe wrote: ↑
25 Mar 2022, 17:48
DCI-P3 is a wider color gamut than common sRGB we're used to in gaming monitors.
Some monitor color settings have a "DCI" or "DCI-P3" setting in addition to existing sRGB profiles.
It has usually been the case that only premium monitors (like ASUS/EIZO professional art monitors, either ultra-premium LCD backlights, or OLED monitors) tend to focus on reaching beyond DCI-P3, and none AFAIK are able to reach Rec.2020.
Credit: https://eizo.es/producto/cg319x/
Posted: 25 Mar 2022, 19:09
by Softhe
25 Mar 2022, 18:00
Softhe wrote: ↑
25 Mar 2022, 17:48
I see, btw has any one gotten display scaling working on non native res? I get black bars when using no scaling...
Posted: 28 Mar 2022, 11:52
by Softhe
Figured out how to force display scaling here's how my cru looks for anyone want to do it https://i.imgur.com/SoUwyoc.png
Posted: 28 Mar 2022, 14:02
by lyrill
Softhe wrote: ↑
28 Mar 2022, 11:52
why does your hz all dip below 390.00? and why do they vary a bit too among diff res
Posted: 28 Mar 2022, 16:27
by axaro1
Softhe wrote: ↑
28 Mar 2022, 11:52
I'm sticking to Nvidia Control Panel because I'm failing to change timings even when deleting every resolution (Standard, Established, Detailed), deleting every single hardware block, sticking to DisplayID 1.3 and 2.0 and putting them on top to force priority, I hope that ToastyX will fix this issue in the near future.
I'm currently using a custom 1920x1080p resolution with 1200VT and 2000HT, I'm wondering if I could get different results with CRU...
