So in other words fighting games such as Street Fighter V that are 60 fps only would experience input lag then?speancer wrote: ↑18 Sep 2020, 16:48DukeDice929 wrote: ↑18 Sep 2020, 16:35I have no issues with input lag using 280Hz VRR on while playing single player games such as Control (very demanding game). As for multiplayer games, I prefer every sync features to be off. (vg259qm)Yep, this is misleading, and no, they don't act the samePeople think that when you have your refresh rate set to 240/280 Hz and turn VRR on and drop to 60 fps you'd get that super-high input lag, but you don't. High input lag issue only applies to fixed/locked 60 Hz scenarios (with or without VRR). So yeah, if the game is not locked on 60 Hz and your monitor is set to 240/280 Hz, then you still have very low input lag if fps drops to 60 in VRR.
.kernel 0x000
Stevie66
Yep it's locked to 60hz so you will get the high input lag..kernel 0x000 wrote: ↑23 Sep 2020, 20:13So in other words fighting games such as Street Fighter V that are 60 fps only would experience input lag then?speancer wrote: ↑18 Sep 2020, 16:48DukeDice929 wrote: ↑18 Sep 2020, 16:35I have no issues with input lag using 280Hz VRR on while playing single player games such as Control (very demanding game). As for multiplayer games, I prefer every sync features to be off. (vg259qm)Yep, this is misleading, and no, they don't act the samePeople think that when you have your refresh rate set to 240/280 Hz and turn VRR on and drop to 60 fps you'd get that super-high input lag, but you don't. High input lag issue only applies to fixed/locked 60 Hz scenarios (with or without VRR). So yeah, if the game is not locked on 60 Hz and your monitor is set to 240/280 Hz, then you still have very low input lag if fps drops to 60 in VRR.
.kernel 0x000
Stevie66
Pretty much all of them except the Asus which has high 60hz input lag..kernel 0x000 wrote: ↑23 Sep 2020, 20:49Damn. Is there a 240Hz monitor that doesn't perform poorly at 60Hz?
.kernel 0x000
Boomchakadah
For anyone who's interested, here's another review of the MSI MAG251RX. http://playwares.com/dpreview/57916781
I'm not a an expert in reading response time tables, but that MSI appears to be faster than the ASUs VG279QM. http://playwares.com/dpreview/57710387
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
- axaro1
The MSI is 0.1ms faster than the VG279qm if you compare Faster with OD80 but OD80 on the VG279qm is 100% overshoot free and Faster on the MSI has 7.3% overshoot.Boomchakadah wrote: ↑24 Sep 2020, 05:00For anyone who's interested, here's another review of the MSI MAG251RX. http://playwares.com/dpreview/57916781
This testings of the MSI show that the response time with Faster is in line with the Vg259qm (2.6ms G2G with OD120), probably due to both monitors using the same panel and achieving similar overdrive performances and the ufotest with Faster vs OD120 looks basically the exact same.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
- RealNC
If you're using an nvidia card, you can force max refresh rate in the nvidia panel. I don't know if AMD has a similar setting..kernel 0x000 wrote: ↑23 Sep 2020, 20:13So in other words fighting games such as Street Fighter V that are 60 fps only would experience input lag then?
kofman13
I just wanna chime in here i haven't even visited blur busters in two months because ive been loving my new monitor so much. but i just wanna say Acer XB273X is hands down the best monitor ive ever tried. $499 well spent lmao (rip wallet)
RLCSContender*
had my predator xb273 x NOT have a dead pixel, i would still be owning it right now. OD Off in my opinion is the xb273 x best overdrive settting.
I miss its variable overdrive. it was among the best feature about the ONLY native 240hz IPS monitor.
@thasios, i owned FOUR msi mag251rxs, all FOUR of them had different white balance for the optimal 6500k requirement. If you meant lowing the gain(color temperature) Red/Green/BLue, that is unique to your monitor. Essentially, you can adjust it to control the OD voltage for some odd reason. (don't ask me why). I was able to successfully do it on some monitors(including the mag251rx), then again ever since i found out the msi had the best motion clarity at 240hz, there's really NO NEED to do it. Just put it on "fast" and you are good to go.
Here's an example. The Predator xb273 x, i was able to lower the overshoot from 6% to 2.5% just by controlling the RGB(color temperature). Unfortunately, each unit is different. But generally speaking. lowering red and green by increments of 5 is usually the first thing I do.
Before(UFO on the LEFT) (ufo on the right is the aw2521HFL, my current main)
After(UFO on the left) (UFO on the right is the aw2521HFL, my current MAIN)
the Alienware AW2521HFL #3 in overall motion clarity vs the Samsung Odyssey G7 27"
image storage
Here's a sample of the upcoming odyssey g7 27"(0/10) and odyssey g7 32" (1/10) review) part 4( i have 6 parts)
(0.5/10)
