Hello guys,
So i just found a video on YT of a Russlan guy whos explaining what he did to fix he's issue with input lag.
I tried to find the filter he was talking about but looks like its only available in Russla...
If someone here can translate what he is saying in the video ?
Thank you
Sharing my findings
- kriegsnake
Re: Sharing my findings
He changed the automatic power switches in his flat to new ones(just in case) and put the filter on the single switch for the room where the pc is . He also said that changes haven’t appeared instantly, in 2 hours it was better in a day it was perfect and after a week it is still ok.
P.s : he doesn’t have grounding and the filter is single phase .
- Yagami
Check the description:
How I corrected inputlag/How I corrected inputlag/fix inputlag
1. replaced circuit breakers
2. Brought a separate phase to the group that feeds the sockets in the room
3. Set the network interference-canceling filter FS-16m (3900 p.).
4. I want to note that I did not change the cable line in the apartment.
5. My computer is powered through the apc network filter
6. If the network filter does not work, regenerators or power filters must be used that suppress the DC component in AC voltage and noise. (isol-8)
Sorry, I record the video for the first time, I did it in order to share it with people.
If someone helped, you can send as a thank you - 2202 2022 3559 9762
