How to change bios hidden parameters (videoguide)
- Slender
bandicam 2022-06-16 06-15-31-563.mp4- (4.48 MiB) Downloaded 256 times
- Slender
Re: How to change bios hidden parameters (videoguide)
after change settings in grub you need to write "reboot", if you poweroff pc change not apply
kokkatc
Nice. Thanks for this.
I've been wondering about BIOS modding for awhile... definitely going to give this a try.
sherifmagdy32
Have been looking for something like this for a while thanks a lot for sharing
Kentar
What is grub? I didn't see it on the video.
JimCarry
Thanks for sharing but this looks to hard and complicated for me.scewin was so easy just change setting restart and boom you are good,f@ck me.
agendarsky
- Slender
JimCarry
i think i send you private msg with my mb model?agendarsky wrote: ↑24 Jan 2025, 10:22send me your motherboard's name into dm , if you have flashback function i can unlock it for you.
btw goodjob slender![]()
SeekNDstroy
Do you know/ have any idea if i use grub, and then try to scewin, will it work?
For some reason, my system freezes if i use the export cmd (with enablelua fix). So i had to use the grub.
However, recently i found that, instead of writing "export", if i copy-paste the full command inside of the command file, it works. Nice! Problem solved. Then i changed a few one & try to import. But it always says fail. Even without modifying anything, just export & import also fails.
As grub takes more time & precision, im not willing to flash a fresh bios just to check the scewin at the moment. I may do that later when i will get extra time. I need to be sure that scewin must require a fresh unmodified bios to work or not.
