Page 1 of 6
5800x vs 12700K competitive fps player
Posted: 26 Jun 2022, 03:02
by Loubie
Hey,
So a friend of mine told me that he went from a 5800x to a 12700k (he plays cs go, while I play valorant) and he told me the difference is night and day, and told me that there was insanely less input lag on his intel cpu, he switched rather recently and had a 5800x.
It's not that I do not believe him, but is this really true? I kind of want to try it out or even "upgrade" to intel if that's the case, anyone has heard about this?
edit: forgot to mention, we both had the same RAM (Crucial Ballistix Elite 3600, he was using DOCP when he had his AMD cpu while I played a bit for lower timings)
Re: 5800x vs 12700K competitive fps player
Posted: 26 Jun 2022, 04:40
by Boop
https://cpu.userbenchmark.com/Compare/A ... 4085vs4119
Maybe you'd get 10-20% FPS improvement but any input lag would be negligible. I think it's more likely he had something wrong with his Windows OS or something in his config causing the input lag.
Posted: 26 Jun 2022, 09:05
by MegaMelmek
Benchmark is marketing and they catch some ppl… Its true that Intel has less input lag in games because they are developed to be played on intel…
Posted: 26 Jun 2022, 09:45
by BTRY B 529th FA BN
Posted: 26 Jun 2022, 09:56
by MegaMelmek
You think his 12700k will be diferent then mine 12700k or his 5800x will be diferent then mine 5800x? i dont think so....
Posted: 26 Jun 2022, 10:01
Posted: 26 Jun 2022, 10:17
by Yagami
It looks more like a placebo effect. I have a PC with 5900X + RTX 3060 and 3570K 4.8GHz + GTX 1060 6GB. I don't feel any difference between one PC and another, although nowadays I rarely play games because of the problem I've been suffering from online games.
Posted: 26 Jun 2022, 12:47
by Slender
Loubie wrote: ↑26 Jun 2022, 03:02
Hey,
i switch 9700k to 12700k, my mice feel very bad, very high lag, inconsistent.
Posted: 26 Jun 2022, 13:10
by Loubie
BTRY B 529th FA BN wrote: ↑26 Jun 2022, 09:45
Did you get the opportunity to test CS:GO on his machine then immediately play CS:GO on yours? Only way to tell is an Apples to Apples setup
True but he lives abroad now I didn't have the chance to do it, but it got me really curious
Posted: 26 Jun 2022, 15:20
