AMD Socket AM4 bios settings
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 09 Jul 2022, 10:12
Last edited by BTRY B 529th FA BN on 07 Aug 2025, 17:46, edited 15 times in total.
Re: AMD bios settings
Post by Slender » 09 Jul 2022, 23:48
Thank you
kokkatc
Post by kokkatc » 10 Jul 2022, 03:31
What's your goal, highest frequency or lowest latency? Disabling C-States will always yield lower system latency which results in a snappier and more responsive mouse. This can be confirmed with latency monitor. Even if your power plan is set to high/ultimate/bitsum with USB select suspend disabled, CPU max/min 100%, pci power savings disabled, latency will be higher with C-States enabled in the bios.
So if you want lower latency for say a competitive fps game, you want C-States disabled.
In the link you posted: https://developer.amd.com/wp-content/re ... 5_0.75.pdf
Go to section 2.14. It states even there for a low latency workload, you should disable C-States for higher performance. When switching between sleep and full power mode there will always be delay and jitter.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 10 Jul 2022, 10:49
Tell
Post by Tell » 10 Jul 2022, 12:32
Can you share your reasoning for these settings? Why SOC P-State P1 instead of P0? Was there problems with the highest performance P0?
What did you gain by forcing HPET? That change seems very strange.
kokkatc
Post by kokkatc » 10 Jul 2022, 23:05
BTRY B 529th FA BN wrote:
10 Jul 2022, 10:49
Just trying to help. You're welcome.
I wanted to apologize if my post came out rude. Awesome thread you started with great info. I just wanted to comment on C-States since you mentioned you left it on auto. Hoping this thread provides a lot of good info for Ryzen builds looking to optimize their bios.
kokkatc
Post by kokkatc » 10 Jul 2022, 23:07
Tell wrote:
10 Jul 2022, 12:32
Great questions. I'd love to hear your explanation for using these settings as well, especially where you decided to enable hpet which is very strange indeed.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 11 Jul 2022, 10:58
Tuhin Lavania
Post by Tuhin Lavania » 13 Jul 2022, 12:51
I tried some of the OP settings and they seem to have an effect on the input lag i was facing in Halo Infinite. I have playd around 20 matches to come to this conclusion.
I will add to this. I have a 5950x and putting Core levelling mode to 4 and on one CCD really decreases a lot of latency. So basically i have 12 cores disabled and i play on 4 cores on a 5950X.
Post by Slender » 13 Jul 2022, 15:03
Tuhin Lavania wrote:
13 Jul 2022, 12:51
5950x have 8+8 ccd, just disable 1ccd and give like 5800x.
lol
