Settings to try out for those with inconsistent mouse speed
hardhit
Post by hardhit » 07 Aug 2022, 12:42
Hello,
I'am sharing my configuration which may improve the feeling of heavy crosshair movement.
[1] Monitor settings
Navigate your monitor settings, find aspect ratio. Select Original (1:1)
[2] Nvidia scalling
To prevent monitor from displaying blackbars with original (1:1) scaling, use scaling on GPU.
[3] Nvidia game settings
I prefer having nvidia low latency set to ON.
[4] Bufferbloat
If there is additional network traffic while you are gaming, because of bufferbloat hit registration will be impacted negatively.
https://imgur.com/a/lV549K9
[5] UDP throttling by ISP
Incase you encounter UDP packet throttling by ISP, you can use cloudflare warp+ service to improve routing and bypass various restrictions.
wgcf can generate a free warp client configuration.
warp+ can also be free if you perform your research on the internet.
https://imgur.com/a/FkBsZhP
For some reason I can't attach more than three pictures.
BTRY B 529th FA BN
Re: Settings to try out for those with inconsistent mouse speed
Post by BTRY B 529th FA BN » 07 Aug 2022, 19:57
Never heard of UDP packet throttling by an ISP,, interesting.
Post by Slender » 08 Aug 2022, 23:45
hardhit wrote:
07 Aug 2022, 12:42
Hello,
[2] Nvidia scalling
[4] Bufferbloat
FREESYNC ON
DPRTMELR
Post by DPRTMELR » 09 Aug 2022, 03:08
this could be nice if it doesn't involve trial accounts and such. will research later D:
Most adults need 7-8 hours of sleep each night. - US FDA
hardhit
Post by hardhit » 09 Aug 2022, 03:45
DPRTMELR wrote:
09 Aug 2022, 03:08
Sign up for cloudflare teams, it is free. Then generate free credentials with wgcf.
1. Connect with wgcf credentials, run command wgcf trace. Expected result warp=free
2. Find video on youtube how to extract warp teams (warp+) credentials with android studio.
3. Replace private key within free wgcf credentials with the extracted private key from warp teams using android studio.
4. Run wgcf trace. Expected result warp=plus
PM me if you need more detailed information.
Stimpy7314
Post by Stimpy7314 » 09 Aug 2022, 06:23
Warp+ definitely helped. I recommend it to use it! Only use warp+ cost 5$ per month or if u want it for free u can try: https://github.com/navaneethkm004/warp-plus
DPRTMELR
Post by DPRTMELR » 09 Aug 2022, 07:02
I went with $5 purchase on the phone app because I just can't figure it out after an hour and i can't spend any more time on this. I don't know if it will make any differences to the gaming but eh. we will see
assombrosso
Post by assombrosso » 09 Aug 2022, 07:25
Did way more than those, nothing helped. U gotta realise pros don’t do these , they play default but if it helps u, it helps u
Shade7
Post by Shade7 » 09 Aug 2022, 10:01
How do I get Warp+ (the paid version). I tried the free one last month, but didn't really do anything. IDK if I'm stupid- but I can't seem to find where to purchase/use the paid version.
Unreazz
Post by Unreazz » 09 Aug 2022, 10:16
Can you explain how this works, what i have to download ? Do i need to do this with normal CMD ? Since its not working for me
