adjust desktop size and position
Posted: 10 Aug 2022, 10:22
by roro13200
hello I would like to know what is the purpose of the option to adjust the size and position of the desktop? in nvidia
does it affect games?
what are the recommended settings for this option?
thank you
Re: adjust desktop size and position
Posted: 10 Aug 2022, 11:18
by Kyouki
Don't touch it unless you need it type of thing.
The scaling modes will scale based on what you set there, so in the case of you playing a game on a non-native resolution like a 4:3 aspect ratio resolution it would scale depending on the setting. Aspect Ratio would maintain the aspect ratio. Fullscreen would stretch it out, No scaling would put it in the middle or within the monitor's borders and not sure on Integer Scaling - haven't used it.
Perform scaling is best done on the GPU, some people argue the Display option has less input latency but I have found that GPU works better plus if you use Gsync or Freesync seems to work better for games to engage into the mode.
Resolution and refresh rate are for the first bunch of options to test. Never used "Size" portion, so can't say but that seems like the older problem of where the image didn't fit entirely into the monitor frame.
