Hello. I have a LG ULTRA GEAR 24GN600 monitor (1080p/144hz, IPS G-Sync compatible, I connect via DisplayPort).
I usually add custom higher resolutions with Nvidia Control Panel and don't have trouble getting G-Sync to work on DX11 or Vulkan games, but on DX12 games G-Sync never activates.
One solution I found was using CRU. It works and when I create resolutions using an Extension Block, I can go as high as 4k/90hz without the screen glitching. But I wonder if I can damage my display because the pixel clock goes up to 800Mhz, which is way beyond the limit I get when I add the resolution as a Detailed Resolution (which only goes as far as 4k/72hz and I still get glitches that way).
Why is using extension blocks more flexible? Can I actually damage my screen with custom resolutions that take pixel clock that far?
GSync on custom resolution
Stingy McDuck
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
