Apologies if a solution to this already exist. I looked and could not find this info.
I am trying to use CRU to display scale instead of GPU scale. The issue is I cannot get it to work stretched res (1728x1080) at a lower frame cap(144-190hz) while using dyac. I cannot get consistent 240hz in apex so I would like to cap frames and use dyac so that strobbing=frames. I cannot get CRU to work using lower frame cap, dyac, display scaling, and stretched res at the same time. The main objective is to cap my fps to a lower refresh and then match the dyac strobbing to the lower frame cap on stretched res. I think the only way to do this is through cru. If anyone has figured this out please let me know. Any help is appreciated, thanks!
