My mouse polling rate is jumping all around on different mice. (FK2, GPRO, MZ1, VIPER Mini) With all of them results are similar. Results attached below i consider "good", becaue they were achieved with everything on the background complietely disabled. Under load it can be much worse, with moustester showing spikes to 3000-10000+hz(how is that even possible?)
125hz looks like this
here is how mousemovementrecorder looks
What i`ve tried:
Setting affinity to core 4 for usb, core 2 to gpu = no effect
Disabling XMP = no effect
Trying different VCORE = no effect
Changing Spread Spectrum to 0.5% from 1.5% default in bios (impossible to disable on this motherboard) = no effect
Reinstalling windows (currently on stripped LTSC) = no effect
Different VCCIO, VCCSA values = no effect
Disabling prefetching, voltage optimization, EIST, Speedshift, Race-To-Halt, Turboboost etc, basically almost whole "advanced cpu settings" is set to disabled right now except overtemperature protection = no effect
Disabling c-states = no effect
Removing power limits = kinda made it better, because until this was done it was even worse
Changing LLC = no effect
Using different USB ports = no effect
Enabling legacy usb = no effect
HPET windows fuckery = dont remember, probably also nothing, currently everything on default
If some of you had similar looking graphs and somehow made it normal, please tell me what you did because im running out of ideas right now
Config:
9900k 4.7 1.2v, Gygabyte aourus master mobo, DDR4 3600
Mouse polling rate is absolutely unstable
1111111111111111iiii
kokkatc
Re: Mouse polling rate is absolutely unstable
I have 4 things you can try that I didn't see on your list.
I didn't see any mention of your power plan settings, so make sure you're using windows built in high performance or ultimate performance (you have to add this plan via powercfg/cmd) plan. Go into the plan's advanced options and find 'USB Selective Suspend Setting' and make sure it's 'disabled.'
I also recommend disabling all power saving on USB devices which is done in device manager. Go to device manager and disable power savings for 'Universal Serial Bus Controllers' and 'Human Interface Devices.' Right click on every device and disable power savings for the ones that allow you to disable.
Make sure your USB controller is in MSI mode. Easiest way is using MSI mode util V3 or v2. You can google this and download. When running this app make sure to run as ADMIN or it won't work.
Lastly, try using timer resolution and running it at .5ms. This significantly increases the amount of interrupts fired on your system which improves responsiveness and lowers latency. ISLC is a good tool for this. Run this application as admin, set your timer resolution to .5ms and keep it running in the background when gaming.
https://www.wagnardsoft.com/forums/viewtopic.php?t=1256
I posted a couple of snips to help.
You may want to consider updating your drivers as well (nic, sound, etc). You could have a faulty driver causing DPC latency issues negatively affecting your mouse.
- USB SELECTIVE SUSPEND.png (18.5 KiB) Viewed 18689 times
- USB POWER SAVING.png (62.47 KiB) Viewed 18689 times
SeekNDstroy
During this mousetester test, make sure you are on high performance/ all powersaving/cstates/turbo/speedstep/eist disabled which you already did. Also cap your cpu clock at stable frequency.
Then make sure your mouse is on the first port(usbtree is a good software for check) .
If hyperthreading is disabled, consider disable idle(cpu idle states) from powerplan using powersettings. If enabled, then don't need it.
Then by using processhacker set csrss priority to high & set csrss & dwm core affinity on same core. Make sure its not the usb's core affinity. Google djballman github & follow
GamingPCSetup/CONTENT/RESEARCH/SOFTWARE/README.md -> there you will see mousetester guide for this step & how to improve it.
Risedo
Use Legacy Console mode will show stable 1000 hz
skkiNN
InputLagger
We have several threads for unstable mouse polling rates, like this viewtopic.php?f=10&t=9304&p=73941#p739411111111111111111iiii wrote: ↑25 Sep 2022, 14:57My mouse polling rate is jumping all around on different mice. (FK2, GPRO, MZ1, VIPER Mini) With all of them results are similar. Results attached below i consider "good", becaue they were achieved with everything on the background complietely disabled. Under load it can be much worse, with moustester showing spikes to 3000-10000+hz(how is that even possible?)
What i`ve tried:
Config:
I think this is artifact from "main" input lag issue which computer was affected (if we got 1000hz stable, I suppose when input lag is gone). We can see such graphs because of this. Any other artifacts we csn only feel and see in front of pc
Look at 1000hz STABLE mouse polling rate (computer without inputlag) https://www.youtube.com/watch?v=Ltd_5MazTgM
https://zowie.benq.com/th-th/support/mo ... ecker.html
zowie.benq.com/th-th/support/mouse-rate-checker.html
x7007
- Screenshot 2023-09-06 224842.png (33.38 KiB) Viewed 15173 times
