what is the best Frame limiter?
yuri
Post by yuri » 04 Oct 2022, 07:43
Hello everyone.
I use NVCP frame limiter, but what is the best Frame limiter to cap without any issue with G-sync?
should i kept NVCP limiter or RTSS or in game caps ?
Kyouki
Re: what is the best Frame limiter?
Post by Kyouki » 04 Oct 2022, 08:24
Think this is a good benchmark that might answer your question.
https://old.reddit.com/r/allbenchmarks/ ... idias_fps/
Post by jorimt » 04 Oct 2022, 08:32
yuri wrote:
04 Oct 2022, 07:43
Short answer is there isn't any single "best" framerate limiter for G-SYNC. It depends on what "best" means to the user and what they're trying to achieve in the given game (including how the particular game reacts to the selected limiting method).
Generally, NVCP MFR and RTSS afford steadier frametime performance over most in-game limiters at the cost of slightly higher (1/2 to 1 frame of) latency.
yuri
Post by yuri » 05 Oct 2022, 14:47
Kyouki wrote:
04 Oct 2022, 08:24
thanks!
yuri
jorimt wrote:
04 Oct 2022, 08:32
yuri wrote:
04 Oct 2022, 07:43
okay, i see thanks!
