I fixed the strange delay.
Posted: 04 Oct 2022, 21:47
I solved my problem with the alleged "input lag" by changing the mousepad, glides on the mouse, and the internet...
mousepad: Razer strider (I recommend this pad! Almost like a top artisan)
mouse: xm1r (if you have a logitech g102, I recommend changing this mouse for another... because the sensor g102 has flattening which gives the effect of buoyancy...)
and recommend ordering tiger ice glides, they are sold on ali.
Just when the mousepad is swampy and the glides on the mouse is also erased, this greatly affects the "perception" ...
about the internet, everything is relative ... with pingplotter it is possible to see some network problems ... but, I recommend to connect Rostelecom via GPON if everything is still bad then, unlucky....
On the way from the computer to the game server, data packets pass through many nodes, from a few to several dozen.
Problems in the work of even one of the nodes - whether it is the user's router or the provider's server - can lead to "lags" and high pings, "teleports", unstable network connection, which is accompanied by "drop-out" from the game.
When your hands sweat a lot, the mousepad becomes boggy and so the mouse starts to drift... That's why you better buy the SkyPad 3.0... Or do hand surgery like XANTARES. (And don't forget good mouse glides! tiger ice for everyone!)
[Moderator Note -- Removed some text and meme style imagery that was embedded at bottom of post -- "Be Nice" and "No Meme" rule violations.]
