hello everyone
my question is what is better for lower input lag?
i play tf2 on 1920 x 1080 (not native res) and my gpu is a rtx 3060 ti, cpu 8700k
i heard that with the new cards its better to use gpu scaling for non native res, however i could not find a good answere on reddit etc. thanks
Nvidia Perform scaling on display or gpu?
Jefersonhungria
Re: Nvidia Perform scaling on display or gpu?
GPU!!!
This generates a lot of discussion because there are certain monitors that scale better than others, so when in doubt the gpu will always be the best option.
*important to remember that you must disable a monitor scaling
Kyouki
The Chief once posted about this topic and upon personal experience with Gsync it is better to run all displays on the GPU scaling mode/option.
If you have one set to GPU and another to Display, Gsync might get confused and pick the max refresh rate from the Display set scaler.
Also really rarely found any differences swapping them over the years, always returned to GPU for sake of mind.
Here is Chief's words:
viewtopic.php?t=6155
