Page 1 of 4
Can "input lag/desync" eletrical issue come back in a new house?
Posted: 15 Oct 2022, 08:55
by Cyanide_
Hey guys, I'm gonna make long story short - I have suffered from this "input lag/desync/electricity related lag" for a year, since summer 2020. It was an old house and several outages happened there, and so this lag began.
After that I moved houses in summer 2021, after realizing it's electricity related and there's no other solution. I moved my PC to a "good" house before, and saw an immediate improvement, and decided to relocate.
Everything worked fine in a new place, for like 3-4 months, I had normal 240hz high lvl FPS experience again, but then lag came back.
It's not the same, it's less severe, it's back and forth (sometimes it's totally playable, sometimes it's a blurry/choppy/jittery mess). But I think this is it, because I have tried literally everything, again, from moving my PC to other places (with no success this time), to swapping parts, applying every single tweak imaginable, reinstalling windows drivers etc. dozens of times, and so on.
My symptoms now are:
- image is not smooth on screen, it's like playing with 70-90 fps while having 240 hz screen, most of the time;
- keyboard input is "delayed", even now I'm typing and it feels like typing from remote controlled machine, if that makes sense, there's same amount of "lag";
- mouse movement is weird, sometimes it's precise, sometimes it runs like I'm using it on glass or ice, depends on tweaks(?) idk;
- internet is "slow" as well, or maybe "slugginsh" is a better word, opening websites is slow, (pre)loading stuff in launchers (Steam, Origin) with some noticeable delay, messengers & their data is slow, there's like 0.2-0.5-1s perceivable delay every time, I might look further into my Mikrotik hap ac2 router & connection, for like packet losses and such, but anyway (btw this whole lag persists even when playing offline or via mobile internet with LAN turned off in BIOS);
- this "lag" grows over time, I've noticed that first round or two in R6 Siege are smooth enough, then it's worse & worse;
- using keyboard only, or gamepad, gives me good results bf4 prone vs moving r6 wasd only 1 r6 wasd only 2 but when I'm moving mouse (flicking, prefiring, turning around) it's a mess;
- also when I'm moving mouse, my 1% and 0.1% fps drops drastically r6 with bots r6 tdm online
- fresh windows reinstalls helped me several times, but only for 2-3 days, then "lag" comes back gradually
I've started one thread already viewtopic.php?t=10214 with my specs and more explanation, and you guys gave me some really good advices, I appreciate that, but nothing really worked. Still struggling with this crap.
I also have brand new Gigabyte A5 K1 laptop, which doesn't have these issues (e.g. I'm playing the same game with same settings etc. and even on 150+ fps it's smoother than on PC with 200+ fps).
My question is - is my gear & PC "damaged", is that the best word?
If yes, what exactly is/could be damaged and should be replaced? I can't replace the whole thing now (including mouse, monitor etc) due to IRL stuff going on.
If not, what can cause it? RAM, PSU, Mobo, bad CPU? I've stress-tested my rig multiple times, e.g. in OCCT, no blackscreens or RAM errors (ante extreme for 15 hours), AIDA FPU and so on. All reading are normal to me, temps even went lower after readjusting coolers & cleaning the whole case with 220v air duster lol.
Thank you for any help, or hints in advance.
Re: Can "input lag/desync" eletrical issue come back in a new house?
Posted: 15 Oct 2022, 09:58
by Cyanide_
TL:DR: "input lag" allegedly came back after moving houses and playing perfectly for 3-4 months, what can cause it? Tweaking bios/system or stupid things like reinstalling windows make it better/worse, or completely disappear for a couple days, also it's heavy keyboard/mouse input, FPS drops when moving mouse in game and move weird stuff.
Posted: 15 Oct 2022, 16:05
by InputLagger
Hmm, maybe monitor somehow was affected by this "lag" , look at this post viewtopic.php?f=13&t=9976&p=80488#p80656
He told the issue dissappear and comeback
Posted: 15 Oct 2022, 17:09
by n1zoo
Yes, new apartments and a new pc didn't help.
Posted: 16 Oct 2022, 05:43
by f1ndus
n1zoo wrote: ↑
15 Oct 2022, 17:09
same experience
Posted: 16 Oct 2022, 05:45
by Cyanide_
f1ndus wrote: ↑
16 Oct 2022, 05:43
n1zoo wrote: ↑
15 Oct 2022, 17:09
same experience
Care to ellaborate, please? You moved to a "good" house and changed whole PC (and monitor, mouse, keyboard, headset etc. too), and it didn't help?
Posted: 16 Oct 2022, 06:02
by n1zoo
Iserverthefirelord wrote: ↑
16 Oct 2022, 05:45
f1ndus wrote: ↑
16 Oct 2022, 05:43
n1zoo wrote: ↑
15 Oct 2022, 17:09
same experience
i moved to new house 2 months ago, bought new pc and components - lag still remain xd. my friends who live in same area don't have this issue.
Posted: 16 Oct 2022, 10:50
by InputLagger
n1zoo wrote: ↑
16 Oct 2022, 06:02
16 Oct 2022, 05:45
f1ndus wrote: ↑
16 Oct 2022, 05:43
n1zoo wrote: ↑
15 Oct 2022, 17:09
same experience
Did you tried just swap your and their whole pc setups, along with cables and peripherals?
Posted: 16 Oct 2022, 11:24
by Cyanide_
n1zoo wrote: ↑
16 Oct 2022, 06:02
16 Oct 2022, 05:45
f1ndus wrote: ↑
16 Oct 2022, 05:43
n1zoo wrote: ↑
15 Oct 2022, 17:09
same experience
You probably did it, but bring ur PC to friends area and test it there. Bring their PC to your house and test it, swap components etc.
Although my "lag" persists now even in friend's "good" apartment, where his PC is just rock solid & stable, and in my parents' "good" house as well (where my brother is playing without a single issue, having essentially the same rig). But again it's less severe and I have a gut feeling about some sole component (MoBo, PSU) affecting it.
Posted: 16 Oct 2022, 12:46
by f1ndus
yes i tried new setup on other places, i tried many things when i was semi pro player in cs:go and traveled much on LANs, i had problems on most lans, sometimes better sometimes worse even with stranger PCs, ofcourse other players on lans was playing without problem, my ex-teamate "neofrag" now playing for OG was sitting next to me, he had old 144hz monitor and i had 240, hes game was really really more responsive and smooth like my, i was playing on my team manager PC, ye and i had this f*****g problem :] .. tried everything except ELECTRICITY, ACCOUNTS, malwares.. nothing helped just placebo feeling for few hourse sometimes days in luck.
I firmly believe that is not in head, what i see and feel its something what shouldnt be normal, everything stutter, mouse delayed, heavy, its like be in BIG desync even when i shooting with guns, i am open to talk aboute mental problems
