What do you think about it? Using two PSUs corrects the input lag.
Posted: 15 Oct 2022, 18:01
by Skeezv
Hey, guys! I found a video on YouTube of 2 guys from Russla where they claim that using two power supplies (one on mobo, the other on gpu) corrects their input lag. On the second power supply, the 24-pin connectors are closed and connected directly to the outlet. The guy in the first video claims that after that, his game becomes incredibly smooth. The mouse behaves differently, excellent straights and it feels the real refresh rate of the monitor 240hz. Your opinion? Sorry, English is not my native language.
1) https://www.youtube.com/watch?v=mO1DxYuRXrU
2) https://www.youtube.com/watch?v=mwQyc1Q5tyQ
Re: What do you think about it? Using two PSUs corrects the input lag.
Posted: 15 Oct 2022, 18:43
by delve
do you understand Russlan?
this one of the english comments
"but it doesn't completely fix it. he also said that he connected his old APFC power supply to the video card, separately from the computer, the rest of the parts work from the PPFC power supply"
would be interesting to know how long he tested it.
Posted: 15 Oct 2022, 22:41
by triplese
Its just another 5 cents to theory of electrical nature of input lag. However using 2 PSUs is not recommended, because videocard doesnt getting all power from 8pin connector. Some power (up to 85w if I recall) is getting from PCIe, and doing same can cause problems. You can search info on GPU miners forums, they use 2 PSUs.
What I dont get in this story - why all people ready to spent thousands bucks for buying new PC, but not ready to call lab or electrician with some king like Fluke quality analyzer and take any possible measurements in good and bad place. If that caused by some HF or harmonics in line - it can be easily fixed by cheap LC-filter.
Posted: 16 Oct 2022, 16:43
by MegaMelmek
triplese wrote:
15 Oct 2022, 22:41
I was ordering company for measure they are close by and they do industrial measure… offer was 400Euro/1h but they want describe the issue before after i describe it they cancel the order…
Posted: 19 Oct 2022, 07:28
by Mr1991
I wonder if you can run an ssd/hd off a separate psu also
