using g sync on a freesync monitor with rtx 2060
ramthegamer
hello there, i wanted to ask , how do i best use g sync on my LG24gm79b using rtx 2060 for the lowest amount of input lag, and what settings should i enable in nvidia control panel.
- RealNC
Re: using g sync on a freesync monitor with rtx 2060
https://blurbusters.com/gsync/gsync101- ... -settings/ramthegamer wrote: ↑07 Nov 2022, 10:46hello there, i wanted to ask , how do i best use g sync on my LG24gm79b using rtx 2060 for the lowest amount of input lag, and what settings should i enable in nvidia control panel.
