This fixes the electrical input lag
Skeezv
This thing fixes the input lag, a few people have already helped in the Russlan group where there are 300+ people. Toroidal balanced isolation transformer
https://aliexpress.ru/item/400034986321 ... b7340abb90
texre
Re: This fixes the electrical input lag
Can we get some clipsSkeezv wrote: ↑12 Dec 2022, 12:03This thing fixes the input lag, a few people have already helped in the Russlan group where there are 300+ people. Toroidal balanced isolation transformer
Skeezv
- dervu
Don't be so fast. To be sure, you need months of PC working as expected.
However, I can confirm that it works as fixed.
texre
- dervu
Yes, I have it for very short time. Not the same one as OP, but from another reputable manufacturer.
If you do not want to risk money, don't. Just wait for long term confirmation, but people are impatient...
texre
I’ve seen you in the forms a lot and have talked to you before so I do believe you
- kriegsnake
Can you please attach the link to the device you’ve got? Because the other one couldn’t be delivered to my location.
- dervu
https://airlinktransformers.com/product ... -eucbs1500
Don't blame me, if you buy and it turns out bad after long time.
Time from buy to delivery at my place was around 2 weeks. Total cost with tax and delivery 560 eur + external RCD plug to be safe + power bar needs to have double pole switch - mine already had that (because current goes on both lines simultaneously). You can ask them to place RCD for additional fee.
akylen
Personally, I'm waiting for more time and feedback.
