I just recently plugged in my 144Hz monitor (ASUS VG248QE) and none of the tests I can fun have options for 120Hz, despite saying they should automatically appear with a 120Hz+ monitor. I'm using chrome, is there any setting I have to enable to get above 60Hz?Chief Blur Buster wrote:Edited Update:
See HOWTO: Fix "TestUFO Stuck at 60Hz" FAQ
120Hz not showing up on web tests
Re: 120Hz not showing up on web tests
You have to change your desktop refresh rate.
Something odd happened just now, I used Chrome as well. Close Chrome change desktop refresh rate to 120 or 144 press apply and ok, open chrome and try again.
make sure youre using a windows aero theme
