I have heard multiple different opinions on this question and figured I might as well ask here.
I have a dell g-sync 165hz monitor, but my system can push beyond 165fps in many games (13700k, 4080) I've tried switching between unlocked FPS (Or locked to a 3x interval of 165x3=495) and G-sync (FPS lock to 162 to prevent going over), but it's hard to really get a feel for the differences.
For competitive FPS games at a mid-to-high level(CS Go, Overwatch, Valorant, Cod, etc) Would you say it's better to have a higher frame rate given the rate will be consistent at 400 for example, OR would it be beneficial to lock the FPS at 160-165 with G-sync on? (V-sync off in both scenarios)
I know for most games, having G-Sync enabled is preferred for overall smoothness typically better, but at mid-to-high level play in FPS games some people say that it's better to get as many frames as possible regardless of tearing/syncing/whatever you monitor can output.
Question for competitive FPS games. Which would be better, Higher unlocked FPS or G-Sync locked at the same refresh rate
ohbehave22x
- jorimt
Re: Question for competitive FPS games. Which would be better, Higher unlocked FPS or G-Sync locked at the same refresh
Mentucius
I would say is more personal and about feeling. I personally prefer to play uncapped fps and I always disable gsync in nvidia panelohbehave22x wrote: ↑24 Dec 2022, 13:36I have heard multiple different opinions on this question and figured I might as well ask here.
natalie321
Putting the frame rate first and unlocking your FPS may be preferable if you are more concerned with performance and responsiveness. However,build now gg you could lock your FPS at 160–165 and enable G-Sync to enhance the visual smoothness if you find screen tearing or stuttering irritating.
Worstylolzs
I know it's old thread but how mentucius said it's about your preference. If you want lowest input lag, get no cap and no any sync. For more better input lag buy some 360hz+ monitors.
To g-sync + v-sync i tried once and it's like when you first time tries 240hz. You can't go lower or without g+v-sync anymore
