Re: 1502VT trick/resolutions problem?
Posted: 18 Jul 2014, 07:31
This is normal, the OSD is wrong during the VT tricks. As long as motion looks fully clear at 120Hz, you're good,
Posted: 18 Jul 2014, 10:04
by masterotaku
thizito wrote:like too much screen tearing in movement even with vsync on double/triple buffered (ofc i want it disabled)
You shouldn't get tearing at all if you're using vsync.
thizito wrote:Im with 1502vt,1080p 120hz,AMA high,instanton,black eq 12,sharp 5,brightness 100,contrast 70,2.5m.s persistence and and left notch
gpu scaling, 400fps, -freq 120 ingame
- Set contrast between 40 and 50. 70 is too much, the monitor is clipping colors.
- Your persistence may be too high. I've just tried with 2.5ms and crosstalk is worse than with 0.5ms, at 125Hz. Try lowering it.
Besides, at 400fps you may still see tearing if you are sensitive, I guess.
thizito wrote:after doing my settings in B.B utility i can close it right ?
Yes, those settings remain forever.
Posted: 18 Jul 2014, 16:44
by Falkentyne
thizito wrote:the thing is, it really looks like my csgo ia running 60hz
but capping fps with vsync goes to 120
so im fucked confused
What video card are you using?
I think you're having the 'stuttering' issue with vsync on. AMD card, right?
This has NOTHING to do with the benq. I had this happen on my OLD CRT on a 7970 card, with vsync on. And using a LCD (even with motion blur reduction) simply amplifies those stutters even more.
I never found a solution except to play with vsync off.
This problem doesn't happen on all maps, though. I remember Train being the biggest culprit.
Posted: 23 Jul 2014, 12:54
by qqbr
Hello everyone :) I used 1502VT on 1920x1080 and 1280x960 and i use 128hz + BR-on. works fine and better than 120hz
Posted: 23 Jul 2014, 16:06
by kamill
Hello. What is Your fps_max? 128 or 127 is better?
Posted: 24 Jul 2014, 16:52
by qqbr
I use 300fps max CSGO
Posted: 24 Jul 2014, 18:16
by harrwang38
You should be actually using uncapped FPS in CS GO. The higher the FPS you have the lower the input lag will be. Or so that is the theory.
Posted: 24 Jul 2014, 23:08
by Falkentyne
Harrwang38, check your PM btw o.o
