Sony FW900 or ROG Swift?
rabidz7
Post by rabidz7 » 22 Jul 2014, 12:33
Which one would be the best for gaming? Money, size, and power consumption are not important to me.
Rabidz7 is a: PowerPC Fan, LCD and x86 Hater, and a Plasma/OLED/CRT/SED/FED Lover
sharknice
Re: Sony FW900 or ROG Swift?
Post by sharknice » 22 Jul 2014, 13:51
The swift has a higher maximum resolution and refresh rate and GSYNC. If your rig can handle running games at 1440p I would go with the swift.
rabidz7
Post by rabidz7 » 22 Jul 2014, 14:01
sharknice wrote:The swift has a higher maximum resolution and refresh rate and GSYNC. If your rig can handle running games at 1440p I would go with the swift.
I can't even use G-Sync because I have a 290X. The FW900 can unofficially do 150Hz-200Hz at its 1024x640 and 60Hz-85Hz at 2880x1800. The monitors seem to be about equal in refresh and resolution, but the CRT has better colors, so the CRT defiantly seems better.
sharknice
Post by sharknice » 22 Jul 2014, 14:09
If you don't have an NVIDIA card the FW900 is probably a better option since you can't use ULMB.
But 2560x1440 @144hz is a over twice the refresh rate the FW900 can do at that resolution.
flood
Post by flood » 22 Jul 2014, 14:42
rabidz7 wrote:Money, size, and power consumption are not important to me.
well why not get both :D
spacediver
Post by spacediver » 22 Jul 2014, 15:46
If you have the opportunity to get a good condition FW900 and are willing to invest some time into learning how to do proper WinDAS calibration (I recommend an i1 display pro colorimeter), you won't be disappointed.
Granted, I haven't seen the swift in person, but the contrast ratio of the FW900 blows it out of the water. Also, personally, I have no need to run higher than 1920x1200 resolutions - I think there is a lot more to image quality than resolution.
But perhaps if I saw a swift in person I'd be more open minded :)
Post by RealNC » 22 Jul 2014, 15:48
Also consider that the FW900, even though it says it's 24", it's a CRT, so it's not really 24". It's has more like 22" visible area. So if you're currently on a standard 24" TFT, then the FW900 is going to be a downgrade (when it comes to size, of course, since with everything else, it's an upgrade compared to TFTs.)
rabidz7
Post by rabidz7 » 22 Jul 2014, 15:57
RealNC wrote:Also consider that the FW900, even though it says it's 24", it's a CRT, so it's not really 24". It's has more like 22" visible area. So if you're currently on a standard 24" TFT, then the FW900 is going to be a downgrade (when it comes to size, of course, since with everything else, it's an upgrade compared to TFTs.)
I'm using a 21.5" right now.
spacediver
Post by spacediver » 22 Jul 2014, 16:00
22.5 viewable, but yea, I believe the 24 inch just refers to the size of the entire faceplate, not the viewable area.
sharknice
Post by sharknice » 22 Jul 2014, 16:07
spacediver wrote:If you have the opportunity to get a good condition FW900 and are willing to invest some time into learning how to do proper WinDAS calibration (I recommend an i1 display pro colorimeter), you won't be disappointed.
I totally agree there is a lot more to image quality than resolution. I'm looking at it from a pure competitive gaming standpoint.
It is much easier to hit long range targets using 2560x1440@144hz than 1600x900@144hz or whatever resolution you need to lower the FW900 to get that refresh rate. In certain circumstances using the higher resolution you'll be able to make out a head and arms and at the lower resolution you'll only be able to see a tiny blob of pixels. Instead of landing a headshot you'll just be hoping you get a hit.
