Can C.R.T Monitor Overclocking Damage The Monitor?
Posted: 22 Jul 2014, 12:34
by rabidz7
I know that if a LCD is overclocked to high, it just blackscreens and doesn't suffer any permanent damage. However, I am considering getting a FW900 to replace my junk TN/77Hz/1920x1080, but I want to have a higher-than-stock refresh rate. Can overclocking a C.R.T monitor cause permanent damage?
Re: Can C.R.T Monitor Overclocking Damage The Monitor?
Posted: 22 Jul 2014, 14:46
by flood
I think it automatically stops working once out of the max horizontal scan rate is exceeded
Posted: 22 Jul 2014, 15:48
by spacediver
with the FW900 you'll be able to get at least 85hz at 1920x1200. I play quakelive at 1280x800 @ 140hz, and do single player gaming at 1920x100@ 85 hz.
Posted: 22 Jul 2014, 15:51
by RealNC
Some CRTs don't have protective measures, and they won't turn off or display a warning. Mine didn't, for example. If you have such a CRT, then overclocking it too much *will* damage it. How fast it gets damaged depends on how much you drive it beyond its specs.
Posted: 22 Jul 2014, 16:25
by spacediver
The FW900 gives an out of signal range message if you try to push it too far.
Posted: 06 Aug 2014, 08:46
by sadaki93
Got my CRT to 1440p, seen no problem yet.
