Alternative xg2431
roro13200
Alternative xg2431
Post by roro13200 » 04 Feb 2023, 12:46
hello I am looking for an alternative to the xg2431 which is not found in europe.
I am looking for a 240hz 1080p monitor, with perfect motion blur if possible lol and that supports strob utility
Discorz
VIP Member
Re: Alternative xg2431
Post by Discorz » 05 Feb 2023, 06:10
If u're ok with TN try some of the latest Zowie monitors.
roro13200
Post by roro13200 » 05 Feb 2023, 06:27
do you have a recommended reference? there are so many benq zowie screen lol.
do you know if the viewsonic xg270 is blurbuster approved?
Discorz
VIP Member
Post by Discorz » 05 Feb 2023, 08:13
XG270 is BB Approved but doesn't work with strobe utility.
Idk, XL2546K and similar models work with utility. XL2566K is not officially supported but I see users report it works too.
roro13200
Post by roro13200 » 05 Feb 2023, 09:28
Thank you for your answers
for the xl2546k.
does the dyac parameter work at all refresh rates? or is it a setting that only works at high fps?
roro13200
Post by roro13200 » 05 Feb 2023, 09:33
in fact I would like to buy the xg2431 but in europe I can't find it..
kyube
Post by kyube » 05 Feb 2023, 10:42
roro13200 wrote:
04 Feb 2023, 12:46
There is no "perfect motion blur". I'm assuming you meant lack of/no motion blur.
The only way to achieve this is to bruteforce fps&hz, going up to 1kHz or strobing.
Strobed monitors and good implementations are rare. The only worthwhile implementations (supporting BB strobe utility) are the XG2431 (60-240hz range, tuned by Chief), the XL2566K (100-240hz is supposedly crosstalkless, below that is gimped by BenQ to "save users from flicker") and other BenQ 240hz models.
The higher the refresh rate of a panel, the less crosstalk/faster the panel is, resulting in better strobing.
1440p segment is very stale when it comes to strobing implementations (MSI QD panel and S2417DG have decent strobing iirc, but locked at 1 refresh rate), perhaps the new OLED monitors with software BFI might make it better.
4k strobing is subpar at best, apart from OLED TV implementations.
I'd say the XL2566K, for 100fps and up content, is as good if not better than the XG2431 when it comes to strobing. It made the older BenQ offerings look redundant imo.
Also, the XG2431, from latest rumours, is coming to Europe in spring 2023, might be worth waiting for that if you can't take 6bit+frc and TN viewing angles of the BenQ models.
roro13200
Post by roro13200 » 05 Feb 2023, 11:34
so according to what you tell me, the only valid strobe screen at 60fps and the xg2431, I'm sad
Leonardoii
Post by Leonardoii » 07 Feb 2023, 12:29
Just got an email 10 minutes ago from ViewSonic that the XG2431 is available in Europe (atleast in Romania). So it might be worth it to wait a bit if it isn't available in your country yet.
Proof
Post by Chief Blur Buster » 07 Feb 2023, 18:31
Confirmed, to see some Europe availability finally emerging.
It's also on Amazon UK, if you want to reward Blur Busters with an affiliate fee (2.5%).
https://www.amazon.co.uk/ViewSonic-XG24 ... B097S9SYM5
