Someone can pls tell me how to make this game works with g-sync at 120/144 hz?
G-sync works but the game is locked at 60hz and it's horrible...
G-sync and wolfenstein the new order
- omgBlur
Re: G-sync and wolfenstein the new order
You should take a look at this post that talks about some games being locked into 60Hz.
It's not you or your hardware. It's the developers fault.
CoMa
Yes i know mate, but i mean, there is a way to unlock it?
- omgBlur
A quick internet search shows no signs of a mod or program to unlock it. Apparently it's running on the same engine that Rage is running on and sadly that game could not be unlocked past 60 FPS.CoMa wrote:Yes i know mate, but i mean, there is a way to unlock it?
Sucks when the developers do things like this that only slightly benefit consoles and not PC.
CoMa
ok, thanks man anyway;)
PoWn3d_0704
Can confirm. Tried for hours to unlock to 144hz, as you can still tell that 60hz is lower than 144 even with GSync.
Honestly, I wouldnt have been able to play that game if I didnt have gsync.
Asus VG248QE with GSync. Blur Busters GSync Contest Winner.
