Hello,
I use this screen with 3D vision kit and in 3D, there is a lot of crosstalk - especially when you move. Unfortunately, this option - blur reduction - doesn't work when 3D Vision is activated.
Any way to fix this problem ?
Thank you very much for yours answers.
Blur Reduction and 3D Vision
Re: Blur Reduction and 3D Vision
That is because 3D Vision uses LightBoost, which already includes blur reduction. See LightBoost FAQ at blurbusters.com/lightboost/faq/Ze GURU wrote:Hello,
Crosstalk is unavoidable, but you can reduce it by lowering the "Contrast" and "LightBoost" setting. Also, the 27" panels usually has more crosstalk than the 24" 1ms panels.
Ze GURU
Thank you very much for this answer
I don't see difference when I reduce contrast or lightboost. The crosstalk doesn't seem reduce.
There is a way to use strobe utility when lightboost is activated ? Indeed, nothing seems work with lightboost on.
