Is this normal polling rate for a wireless mouse?
gameinn
Post by gameinn » 09 Feb 2023, 09:30
Hi everyone
I'm abit of a noob when it comes to understanding this stuff. I have a Logitech G Pro Superlight and an Asus Dark Hero X570 motherboard. The CPU is a Ryzen 5950x. I just want to say that I personally don't feel any real problem but after seeing some graphs here I think this isn't normal. Here are 2 typical graphs:
https://i.imgur.com/axjtMqX.png
https://i.imgur.com/c1N9tGu.png
A more zoomed in version when spikes are not shown: https://i.imgur.com/06SIDIA.png
If it matters I'm running 800 dpi. I have at times seen spikes upto 18,000+ Hz but I've also seen some ~500 Hz rates as shown on the graphs. I honestly don't know if I'm doing it right like I try to move the mouse in a circular motion and press f2 then wait awhile and repress f2 to stop the log. I've not done any Windows config it's mostly default and drivers installed via Asus website for lan, audio, amd chipset, bluetooth etc. The only conscious change I've done is move the mouse to the red usb connector on my motherboard and move the keyboard to the blue ones as I know the chief made a post about this. If that has made a difference I don't know but may aswell do it.
I am running latest Windows 10. 22H2 19045.2486. Thank you for any tips.
gameinn
Re: Is this normal polling rate for a wireless mouse?
Post by gameinn » 09 Feb 2023, 11:57
I did have the microe version but there was not a frequency in the drop down list to choose after clicking the plot button. This is why I was using v1.5.3 from dobragab. Maybe I messed something up, probably did.
Brainlet
Post by Brainlet » 09 Feb 2023, 12:28
Dobragab's version is a fork of microe1's old version. You can use Interval vs. Time
Starting point for beginners: PC Optimization Hub
assombrosso
Post by assombrosso » 09 Feb 2023, 13:17
Nothing changing? It’s all the same
gameinn
Post by gameinn » 09 Feb 2023, 16:37
Brainlet wrote:
09 Feb 2023, 12:28
Hopefully this is it: https://i.imgur.com/fiptF7T.png
greenenemy
Post by greenenemy » 10 Feb 2023, 03:28
Looks normal to me, if you want better results you gonna have to spend some hours optimizing windows, bios etc.
Melkxz
Post by Melkxz » 10 Feb 2023, 03:57
Looks good to me.
From my understing you can't achieve insane graph on amd. Especially on high core numbers cpu like the 5950 without tweaking the bios.
As long as your mouse feels good there's nothing to worry about.
gameinn
Post by gameinn » 10 Feb 2023, 07:38
Thanks everybody. I don't know much about bios setting but I could try installing one of those stripped down Windows 10 ISO like Atlas or Revi. Do you think that would have decent improvement or just keep to what I have?
