Have your guys tried replacing your ENTIRE setup?
Posted: 20 Feb 2023, 19:18
by woodyfly
Instead of a new parts or a new PC, has anyone tried replacing their entire setup down to new components down to every single cable, mouse, keyboard and pc?
Re: Have your guys tried replacing your ENTIRE setup?
Posted: 21 Feb 2023, 04:31
by assombrosso
woodyfly wrote: ↑20 Feb 2023, 19:18
Yes I know couple of ppl who said that did it and it didn’t work. only guy who said it helped him, said he had to move to a “good location” and then replace all of his pc components because even the location was good and the lag was gone, it wasn’t fully gone so he replaced all components to fix all the lag, and he was successful.
So if you wana stay at your current location and replace all parts, that woulnt work, the lag will happen in 1-2 weeks max.
Posted: 21 Feb 2023, 06:33
by delve
No, but I plan to test power station plus new setup to rule out damage from bad electricity. If this doesn't work, i am certain, it is emi over air at least in my case.
Posted: 21 Feb 2023, 07:24
by assombrosso
delve wrote: ↑21 Feb 2023, 06:33
Can also be servers/isp , very underrated one,
Posted: 22 Feb 2023, 07:26
by TheKelz
Buying a whole new setup won't help. I have an iMac and a PC here. Both have this issue (mouse is heavy, microstutters overall, etc). One thing to note tho, I had my GPU inserted in a different PC and a location where this issue is non existent and there was no input lag or stutter at all, so I don't think components get "infected" like that. Maybe the motherboard or the PSU, but CPU, RAM and GPU at least should be fine.
