Hi all,
I recently got myself a DualUp (LG's weird 8:9 display) and got sucked down a rabbit hole trying to get it to switch inputs via DDC/CI. My background is mostly in computer engineering, security engineering, and reverse engineering, so I'm hoping I can get some help understanding panel details.
What I've done so far:
tl;dr, this repo is the current culmination of my work: https://github.com/shinyquagsire23/lg_display_manager
I started by popping LG's OnScreen software (which is used for firmware updating) into Ghidra to figure out where it downloads firmwares. As it turns out, it's pretty basic and I didn't even need Ghidra, I could have just run strings. The firmware is stored at https://lmu.lge.com/ExternalService/ons ... 221219.zip, fetched from a constant URL at https://lmu.lge.com/ExternalService/ons ... ersion.txt . The password was 28MQ780!LGdasusodkug!@#
In the zip were 3 firmwares, NXP, PD and Scalar. NXP is the USB microcontroller that's used to update the scalar firmware (apparently it also handles fans?), and PD is for USB-C stuff apparently. The scalar firmware's name was 28MQ780_MSTAR_MST9W00V4_V3.3.0_0x12FBF031_shad4015bb_220317.bin, which gave me a few more data points to drill into, specifically the chip that's used, the MStar MST9W00V4. Eventually I found this extremely annoying post (https://web.archive.org/web/20230223071 ... /123150496) which had the compiler used for the chip and this page (http://linux-chenxing.org/cpu/aeon.html) telling me that my scalar's CPU architecture was proprietary, but based on OpenRISC. It turned out that the stars had aligned or something and there were no less than 3 people interested in this particular ISA in the last 3 weeks, because someone else had asked about it (https://github.com/linux-chenxing/linux ... ussions/81) and apparently a niche disassembler added partial support for it (https://github.com/uxmal/reko/releases).
I ended up adding support to Ghidra for the ISA (it's still WIP bc there's a handful of unknown/incorrectly guessed instructions left, repo is at https://github.com/shinyquagsire23/ghidra-aeon), and with a bit more decompiling and Github scouring I managed to pull apart and decompress the main firmware binary, so I could actually figure out how the DDC/CI commands even worked.
Long story short, LG did not program the features I wanted, and I was too chicken to modify the firmware on the SPI flash (this was partially because while attempting to sniff the USB protocol in wireshark, LG's updater bricked the monitor, so I had to return that one). So I decided to implement the features by brute force: I found a hidden/factory command that basically copied into memory anything I wanted, which meant I could write my own code that did what I wanted into the scalar CPU's memory. This also has the advantage of wiping itself clean on reboot.
Where I want to go:
I started looking into the possibility of running my panel at 120Hz. The main issue is that I don't reaaaaaaallly understand panel timings that well, but I have a full disassembly of the firmware and I can modify anything in RAM, so I can basically tweak/spoof anything, with some work. I'm curious if anyone else has experience messing with MStar panel firmwares or has an MStar driver board and is willing to also pull apart their firmware.
[Monitor Firmware] LG DualUp/MST9U Firmware Hacking
shinyquagsire23
shinyquagsire23
Re: [Monitor Firmware] LG DualUp/MST9U Firmware Hacking
Update: I managed to upclock it by bumping the dotclock timing, as well as the vfreq timings. It turns out the values to look for in the firmware are the exact same as the Debug Info menu in the service menu.
The most I got was ~80Hz before the panel started to do the thing where it looks like burn-in but it's not. After my experiments I was left with a nauseously flickery panel, which thankfully resolved itself after about an hour or so left alone at stock settings, so it's safe to say they didn't secretly ship any 120Hz 8:9 panels (and I probably won't experiment much more with panel stuff lol). The interesting thing to note though is that the default dclk when generated from vt and ht will actually target 66Hz for some reason, but it downclocks to 60hz.
Thank you for posting on Blur Busters Forums!shinyquagsire23 wrote: ↑23 Feb 2023, 17:51Hi all,
As an indie business, we love hearing from display hackers, including monitor firmware modders.
Since your post also include a programmers' component (you created a github repo), I've created a shadow link in the Programming forum too.
Be noted as of February 2023 that I currently work on contract with LG relating to their 240Hz OLED panels (my work affects all their clients including ASUS, Dough, Corsair, etc) so I can't really personally participate in hacking a client's firmware. But there's nothing preventing forum members enjoying sharing their feats and I enjoy reading these. It just means I can't play with your work at the moment, but I love it when users share this stuff!
That can be an interaction with LCD voltage inversion where;shinyquagsire23 wrote: ↑25 Feb 2023, 01:18The most I got was ~80Hz before the panel started to do the thing where it looks like burn-in but it's not.
(A) An overclock somehow disables the LCD's voltage-inversion panel protection algorithm; or
(B) An overclock creates a flicker effect that is in sync with the voltage-inversion, creating a voltage imbalance.
More information about LCD voltage inversion algorithms, and its side effects (flicker patterns, image retention, chessboard patterns, etc):
Purpose of LCD voltage inversion algorithms - viewtopi.php?t=3629
BFI interference with inversion creating image retention - viewtopic.php?f=7&t=7539
rajkosto
I'm trying to do similar arbitrary memory read/write on another MSTAR chip, the spi flash dumper you wrote works on it, so does the firmware extractor it seems but the MAIN section seems uncompressed
Have no idea which memory address to even load the MAIN section in ghidra at, any suggestions ?
- aquajujitsu
Hello! I bought this monitor too.
Imagine that 6 months after the end of the warranty, this son of a bitch breaks down.
Well, it's especially LG's mother who makes me angry.
They don't want to provide me with old firmware that might allow me to reboot it.
Even the ecological cause doesn't work.
It's just for show and tax breaks.
So I turn to the hacker community because they're the only ones who are really nice.
THX
THX
