cheapest 1000hz mouse?
flood
what's the cheapest reasonable 1000hz mouse that can do 1000hz without installing special drivers?
Q83Ia7ta
Re: cheapest 1000hz mouse?
May be Razer Abyssus. H/W switch on bottom sets polling rate. No drivers needed.flood wrote:what's the cheapest reasonable 1000hz mouse that can do 1000hz without installing special drivers?
flood
hm roccat lua is 26$ on amazon.
casedistorted
I am actually looking at buying a new mouse as I only have one with 3 buttons and the rubber things glued to the bottom have worn off. Would this be a good mouse to go with if I want something for gaming?
- fenderjaguar
I have zowie FK which is done by holding buttons on the mouse, before plugging into the USB port.
Don't know if it's the cheapest though
- Wijkert
Like to suggest the Logitech G400(s), but they are eol I believe.
LG 34UM67; GeForce Titan 1058mhz/1700mhz; 2500K 4.4ghz / D15; 8GB Ripjaws 1600mhz; Z68X-UD3H-B3; AX860; 750GB 840 EVO; 1.5 WD Green and 3.0 WD Red; Teufel Concept D 500; Sennheiser HD595; Windows 8.1
