Hi,
I recently reinstalled windows, and gsync was working on iracing on tripple screen monitors (aoc 27g2u) out of the box.
I don't use nvidia surround, but set up tripple monitors using windowed mode in the renderer.ini file of iracing.
The strange thing is that it seems to work randomly, and now i don't get it to work at all anymore (only in fullscreen single monitor)
Yesterday i found that the geforce indicator was shown after i resized the windowed iracing or switched between bordered / borderless in the iracing settings.
Today, i cannot seem to get it working at all anymore...
i use nvidia 3070ti with drivers 511.79
My nvidia settings:
gsync compatible chosen
vsync enabled
use highest refresh rate available
My 3 monitors are set at 144hz in windows, and freesync is activated on the monitors itself.
I use rivatuner to cap the framerate to 141fps
Does anyone have an idea what the reason could possibly be?
I did not change any software or update any drivers....
Iracing tripple monitor borderless freesync not working anymore
fjskmdl
fjskmdl
Re: Iracing tripple monitor borderless freesync not working anymore
Strange thing is, i just power cycled my middle monitor (while the side monitor's were still on).
After the middle monitor turned back on, my open program windows shifted all the the right monitor.
When i then started up iracing, gsync works...
matrox-40
Hello 16 months later... I see the same stories on my side as well. G-sync in windowed mode in iRacing behaves random, sometimes indicator is ON, sometimes OFF but still I see varying Hz in monitor overlay, I would say all scenarios but what is most important - its almost always stuttering. However, it happens that all is butter smooth, but even when just lapping, after 3-4th lap all of a sudden it starts stuttering. Sometimes I shring window/stretch back to 3 monitors and its smooth. Sometimes I move window a bit - it fixes or destroys smoothes. It becomes kind of roullete.
Once when all was super smooth I quit, cloned whole SSD. Then turned on - stuttering. Used cloned SSD - stuttering.
I think its iRacing problem. In parallel I use windowd ACC and there are no problems like that.
