Currently the best settings for Apex Legends
Posted: 23 Apr 2023, 06:59
by Tiberiusmoon
Since I have seen the odd mention of Apex on the forums I though i'd post a guide here.
Now these settings are low latency statictically without IRL latency testing, I consider the FPS, Variances, Drops in FPS and GPU usage which have shown to be significant in IRL latency tests.
This is also with the assumption your system and drivers are up to date and stable.
Each system setup can be different, so your results may differ. (Learn to use CapFrameX and post your results)
Edit: It turns out my GPU usage in Dx12 games was held back by a chipset driver update making Dx11 the best option, I have correct the post
Currently Dx12 will provides low latency while Dx11 provides more FPS throughput when compared to eachother without Nvidia reflex.
BIOS:
If you have 6 or more cores on your CPU disable hyperthreading and the following regardless: C-states, intel speed step, speed shift, and do the same the AMD equivalent.
If your familiar with CPU frequency and voltage tweaks just set all cores to their respective boost clock rating and voltage. (disable CPU core voltage offsets)
Enable 4G decoding, (resizble bar is optional but not utilised properly so it should be left off.)
OS tweaks:
To avoid mistypes in the registry download this app: https://github.com/SanGraphic/QuickBoost/releases
You can save the exe somewhere if you wish to undo settings.
Click Enable Exclusive fullscreen & disable xbox gamebar.
Then Install timer resolution service.
In the advanced section click disable Preemption.
Install RTSS and set the frame cap to 295 for r5apex_dx12.exe. (https://www.guru3d.com/files-details/rt ... nload.html)
-Right click your desktop > display settings > graphics > change default graphics settings.
Enable all options in this window except Hardware accelerated GPU scheduling.
-Settings > gaming > game mode: Enable game mode.
Dx12 Apex Low latency
Ingame:
Fullscreen
Native resolution
FOV scaling: off
Sprint view shake: Minimal
V-sync: disabled
Nvidia reflex: On +Boost
Adapt res FPS target: 0
AA: none
Dynamic stream budget: Disabled
Tex streaming budget: 3GB
Tex filtering: Bilinear
Everything below that is set to Low or disabled.
Launcher commands: -novid +fps_max unlimited -high
Nvidia Control panel:
All settings should be controlled by application, off or auto -in that order- except for the mentioned settings:
Power management mode: Prefer maximum performance
Preferred refresh rate: highest
Tex filtering, Aniosotropic sample: On
Tex filtering, LOD bias: Allow
Tex filtering, quality: High Performance
Tex filtering, Trilinear optimisations: On
Threaded optimisation: On
Notes on settings choice:
-Tex streaming budget and Tex filter quality.
Using the right combination will reduce frame spikes, you can use no Tex stream budget with High performance but its a negligible difference in frame variance and more erratic FPS, given the visual benefits and consistency, 3GB and performance is chosen.
Dx12 vs Dx11 (after tweaking for the best settings)
FPS Avg:
Re: Currently the best settings for Apex Legends
Posted: 14 Aug 2024, 08:36
by IWANTNOMOREINPUTLAG
any updates to this seasons best way to play this horrible game im on windows 11 i play 1440p and i have a 4000cl16 36gb and 13700k and 3090 can u tell me please my game feels horrible and im hard stuck gold , my bios settings are as follows stock cpu with mce off tuned ram (completely stable ), cstates off , hyperthreading off , win11 high-performance core parking disabled , game is dx11 at the moment all low settings and i have HAGS OFF and OFWG OFF
Posted: 14 Aug 2024, 14:21
by Slender
IWANTNOMOREINPUTLAG wrote: ↑
14 Aug 2024, 08:36
try to enable c-state and use c0 limit
Posted: 15 Aug 2024, 11:24
by bleya99
Tiberiusmoon wrote: ↑
23 Apr 2023, 06:59
BIOS:
OS tweaks:
Ingame:
Fullscreen
Native resolution
FOV scaling: off
V-sync: disabled
AA: none
FPS Avg:
I would also add that you should disable shadows in Apex, which can yield around 5-10 fps at constant basis.
Also, you can lower the setting.r_lod_switch_scale from 0.6 to 0.35, which shouldn't really make strong noticeable difference, but might provide a few more FPS (you have to test this on your own).
To disable shadows just replace 1 with 0 on line "setting.csm_enabled" "0"
You can change these settings here C:\Users\Yourusername\Saved Games\Respawn\Apex\local and then videoconfig, if you can't save for some reason, disable Read-Only in Properties of videoconfig.
Posted: 15 Aug 2024, 14:43
Slender wrote: ↑
14 Aug 2024, 14:21
14 Aug 2024, 08:36
what will that do ?
