ROG Swift dimensions
Hel1011
Post by Hel1011 » 08 Aug 2014, 09:28
Asus seems to have the wrong dimensions on its website for the monitor (Phys. Dimension with Stand(WxHxD): 619.7x362.96x65.98mm). I highly doubt the monitor with stand is only 14.2 inches (363mm in inches) at its lowest setting. This is shorter than most 24 inch monitors. This would be great because I am looking for a monitor to fit in a 16 inch high area. However, as mentioned, I am very skeptical of this measurement. Can anyone with the monitor give me the real measurement of the monitor at its lowest possible adjusted height (including the stand if it should stick out above the screen when moved to its lowest height).
Haste
Re: ROG Swift dimensions
Post by Haste » 08 Aug 2014, 10:37
Leyanna from OCN forum did some measurements.
Monitor dimensions:
bezel: 3/8"
outer width: 24" 3/8
outer height: 14" 1/4
depth (without the stand): 1"
depth (with the stand): approx 7"
Base dimensions:
front width: 10" 1/2
rear width: 11"
widest point: 12" 1/2
depth: 9" 1/4
Assembled monitor height:
Minimum (landscape): 17"1/2
Maximum (landscape): 22" 1/2
http://www.overclock.net/t/1455299/asus ... t_22668092
Monitor: Gigabyte M27Q X
