Hello guys, i'm looking for settings like spread spectrum to help me with emi input lag
Basically the usual, at night my games are twice the speed and during days they are slow af
right now i'm using
SB Clock Spread Spectrum on enabled and
SB Clock Spread Spectrum Option on -0,475%
I changed these settings using scewin,
anyone know any other settings that could help me like spread spectrum does ?
my mobo is b450 plus asus tuf gaming plus
Any other settings like spread spectrum ?
Re: Any other settings like spread spectrum ?
Nothing helps too much
- kironashi973
I found SRIS
This one is working well
Anyone know something similar ?
- kironashi973
Looks like that if you want to use SRIS you also need to put pcie gen speed to 4
Does that mean I need to set pci-e 4.0 in the BIOS setup? If my graphics card does not support pci-e 4.0, will sris still work?kironashi973 wrote: ↑22 Jun 2023, 17:21Looks like that if you want to use SRIS you also need to put pcie gen speed to 4
- kironashi973
No idea i saw that on a discord, sorry !
- kironashi973
Anyone know something about this setting i found in scewin ? :
Setup Question = Int. Clk Differential Spread
Token =284 // Do NOT change this line
Offset =A2
Width =01
BIOS Default =[FF]Auto
Options =[00]Disabled // Move "*" to the desired Option
*[01]Enabled
[FF]Auto
Offset =A2
Width =01
*[01]Enabled
[FF]Auto
